| VaccaRabite |
Aug 22 2010, 09:47 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,841 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
If you remember from my last thread, I have started having an issue where my idle was dropping from 1100 to ~500 and the engine would sputter. I thought it was due to clogged idle jets.
Well, Friday I cleaned the dickens out of my idle circuits and set idle back to 1100. Yesterday (saturday) I drove the 914 70 miles to Plaskets' summer BBQ. The car did great until I got to within a few miles of Plaskets, with the idle falling off again. ScottyB and I tinkered with it for a while - checking timing and trying to figure out what the hell was going on. What we found was that the drivers side bank of carbs was dropping out, possibly due to the idle stop backing off. But the carbs were just being wonky. We ended up not really fixing anything. I set idle back to 1100 and headed for home. the 70 mile trip was more or less uneventful until I for a mile or so away from my house. Stopped at a light and almost home, I could feel a cylinder drop off. The idle dropped down to about 1000 rpm and the idle became just a little lumpy. When I got home, I was back to idling on 2 cylinders at 500rpm and the car was sputtering in my driveway while I waited for the garage door to open. I had to keep blipping the throttle to keep it alive. The thing is, as son as you give the car gas, all four cylinders fire up and the car is a blast to drive. Its just back down to idle where I have issues. I am at the point where I am going to unhook the linkage and start from scratch to rebalance everything, and hope that fixes it. If anyone has other ideas as to what is going on I'd love to hear them! Zach |
| brant |
Aug 23 2010, 08:50 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,159 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Murry,
your posts are often negative and belittling. very negative. Even if you have experience and knowledge that is useful, its hard to listen in the way you present. I find very little positive or helpful when you post. perhaps go back and hang out on the originality forum? |
| ME733 |
Aug 23 2010, 10:42 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
Murry, your posts are often negative and belittling. very negative. Even if you have experience and knowledge that is useful, its hard to listen in the way you present. I find very little positive or helpful when you post. perhaps go back and hang out on the originality forum? PM sent...read it. |
Vacca Rabite Carb issues take two Aug 22 2010, 09:47 AM
brant I sometimes have the same issue when hot. I can... Aug 22 2010, 10:54 AM
Vacca Rabite
I sometimes have the same issue when hot. I can... Aug 22 2010, 11:06 AM
neyen14 I had this problem... I have the CB performance li... Aug 22 2010, 10:59 AM
brant are their idle stops on both banks?
I can't re... Aug 22 2010, 11:10 AM
Vacca Rabite
I can't r... Aug 22 2010, 11:20 AM
ME733 ............Well it is obvious you guys have a mod... Aug 22 2010, 11:26 AM
brant
............Well it is obvious you guys have a mo... Aug 22 2010, 11:37 AM
ME733
............Well it is obvious you guys have a m... Aug 23 2010, 08:26 AM
Vacca Rabite Indeed. My car idled like a rock at 1100 rpm all ... Aug 22 2010, 11:48 AM
Root_Werks Zach,
I bumped my 50's to 55's a while ba... Aug 22 2010, 12:20 PM
Vacca Rabite You know, we did not check plugs yesterday. I lik... Aug 22 2010, 01:21 PM
Cevan
You know, we did not check plugs yesterday. I li... Aug 23 2010, 08:51 AM
Root_Werks
You know, we did not check plugs yesterday. I li... Aug 23 2010, 08:55 AM
karnak hi Guys,
i was poking around and decided to join... Aug 22 2010, 02:22 PM
jmill Even with the idle stop screw backing out you woul... Aug 22 2010, 06:59 PM
rhcb914 Not sure what type of fuel filter you are using bu... Aug 22 2010, 07:13 PM
Dr Evil :popcorn: I got nothing.... Aug 22 2010, 08:38 PM
type2man I would first start off with a new set of plugs. I... Aug 22 2010, 11:04 PM
Vacca Rabite My immediate plan of action is this:
pull and insp... Aug 23 2010, 06:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th March 2026 - 12:45 AM |
