| Mueller |
Mar 17 2004, 06:53 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Does anyone have dyno numbers or know where to point me to for a comparison between the two different types of ignition??
Knowing that I can turn my regular distributor into a fully electronic programmable electronic ignition (okay, it'll still have the rotor which must distribute the spark) I was wondering what the crankfire has over the distributor ignition besides 0 moving parts that can wear out. for the distributor the path for the spark still needs to go from the coil>rotor>cap>sparkplug wire>sparkplug.... the crankfire is coil>sparkplug wire>sparkplug what effect does the rotor and cap have on ignition if everything is the same (advance curve and coil rating)???? |
fiid Here is some guy spouting "info".
http://www.rhin... Mar 17 2004, 07:08 PM
Brett W Mike
A crank trigger is the only way to go if you... Mar 17 2004, 07:17 PM
SLITS Crank trigger is dead accurate due to the lack of ... Mar 17 2004, 07:26 PM
rdracrdave The crankfire system is just more precise . The di... Mar 17 2004, 07:30 PM
lapuwali Speaking strictly theoretically, if you have the d... Mar 17 2004, 07:30 PM
Jake Raby I have used crankfire on the dyno against a 009 as... Mar 17 2004, 08:14 PM
DNHunt Megasquirt can already run a Distributorless ignit... Mar 17 2004, 09:50 PM
lapuwali There are a number of variations on the EDIS syste... Mar 17 2004, 10:19 PM
airsix <... Mar 18 2004, 03:04 AM
tat2dphreak :worship: great job airsix!!!
how h... Mar 18 2004, 08:58 AM
Mark Henry Ya'll like my dizzy???
SDS with crankfire....... Mar 18 2004, 09:39 AM
airsix ... Mar 18 2004, 04:13 PM
fiid Coilpacks probably don't generate all that muc... Mar 18 2004, 05:35 PM
jonwatts <... Mar 18 2004, 05:43 PM
Jake Raby Dave, if you are gonna use that on the engine kit ... Mar 18 2004, 07:52 PM
DNHunt Jake
It's in the box. It's indexed via th... Mar 18 2004, 09:08 PM
airsix tat2dphreak, forgot to say thanks for the complime... Mar 18 2004, 11:34 PM
Mueller Hey Ben,
thanks for the info, yes, I knew that al... Mar 19 2004, 12:08 AM
airsix <... Mar 19 2004, 12:16 AM
Mueller I'm giving the Haltech back to Brad...at the t... Mar 19 2004, 12:55 AM
Mark Henry Hmmm....turbo again :idea:
YOU CAN"T TURBO A 914... Mar 19 2004, 09:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th September 2026 - 02:10 PM |
