EdArango |
914 Enthusiast ![]() ![]() Group: Members Posts: 267 Joined: 30-January 10 From: Huntington Beach, CA Member No.: 11,309 Region Association: Southern California ![]() |
Hey Folks,
Is there someone out there that sells brand new wiring harnesses for a 1973 converting from 1.7 to 2.0 carbs?? If so, can you guys let me know who has them??? Thanks ED |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,016 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
The chassis harness should be good for either carbs or FI. (IMG:style_emoticons/default/wink.gif) I am working on a new 914 chassis harness FWIW, should be available sooner than later, I have most of the complications worked out already.
As far as converting to carbs, you will still need your ignition harness and the stock harness design is good for carbs as is, unless you just happen to want or need a new one. If so, contact me, I have them. Here is the link to my harenss website: http://bowlsby.net/914/WiringHarnesses/ (IMG:style_emoticons/default/biggrin.gif) |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,588 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
The chassis harness should be good for either carbs or FI. (IMG:style_emoticons/default/wink.gif) I am working on a new 914 chassis harness FWIW, should be available sooner than later, I have most of the complications worked out already. Excellent, it'd probably be easier to work out the right front wiring issues on my car with a new harness...PO did a real hack-job when replacing the front fender (wires don't operate the correct stuff and grounds suck!). Can't wait to see the new products when they come out! |
Lo-Fi Version | Time is now: 24th August 2025 - 02:45 PM |
