> For you Megasquirt people...., waterproof enclosure w/new board...!!!
Mueller
post Mar 17 2004, 07:22 PM
914 Freak!
This guy redesigned the original MS board to incorporate the relays onto the board and he designed it to be waterproof
This should be perfect for our cars for those that want to mount the ECU in the engine compartment without resorting to tupperware (IMG:style_emoticons/default/smile.gif)
MiniMS waterproof and on-board relay Megasquirt
Dave_Darling
post Mar 17 2004, 09:07 PM
914 Idiot
There is a thread here, use the "search" button (Luke!).
In short--it is a build-your-own ECU. It can be configured to work with stock injectors, and a few of the stock sensors. Pretty much air temp and head temp. RPM is read off of the ignition points (or whatever points replacement you have), load is read by a solid-state MAP sensor, throttle position by a resistor-type throttle position sensor. You have to do some creative adaptation to fit a TPS to our throttles, because they open backwards to most.
It is almost infinitely configurable and programmable--they give you all the source code.
--DD
Mueller   For you Megasquirt people....   Mar 17 2004, 07:22 PM
anthony   Mike, does anyone sell a complete and test Megasqu...   Mar 17 2004, 07:51 PM
Mueller   a guy was selling completed and tested Megasquirts...   Mar 17 2004, 07:55 PM
trojanhorsepower   Mueller, I have read about Megassquirt here, but ...   Mar 17 2004, 08:29 PM
Dave_Darling   There is a thread here, use the "search" button (L...   Mar 17 2004, 09:07 PM
Aaron Cox   lets say you have a carb cam. can you make this wo...   Mar 17 2004, 09:18 PM
Andyrew   two tb's would have to have some wierd linkage...   Mar 17 2004, 10:12 PM
jkeyzer   Waterproofing does not solve the temperature probl...   Mar 17 2004, 10:13 PM
jkeyzer   <...   Mar 17 2004, 10:14 PM
jkeyzer   http://www.mini-ms.com/images/mpx4250.jpg I hate ...   Mar 17 2004, 10:18 PM
Dave_Darling   <...   Mar 17 2004, 11:37 PM
crash914   This is exactly what I am going to do. I have al...   Mar 18 2004, 06:23 AM
ThinAir914   So if the temps in a 914 engine bay are higher tha...   Mar 18 2004, 09:33 PM
Mueller
  Mar 18 2004, 09:58 PM
jkeyzer   I'm mounting my MS inside the cabin. I'll...   Mar 18 2004, 11:55 PM
SpecialK   Man I like the sound of the dual Weber TB FI setup...   Mar 19 2004, 05:23 AM
Kevin@ojai.net   I just finished soldering together a MS board. Ju...   Mar 19 2004, 05:40 AM
anthony   How hard is it to successfully solder together a M...   Mar 19 2004, 10:21 AM
jkeyzer   It's not that hard, but you won't be happy...   Mar 19 2004, 11:36 AM
lapuwali   I'll second the good soldering iron comment. ...   Mar 19 2004, 12:49 PM
Mueller   add a fan to the list...I normally just use a smal...   Mar 19 2004, 01:33 PM
jkeyzer   I like solder wick and I use it a lot. Use the so...   Mar 19 2004, 02:24 PM
- Lo-Fi Version Time is now: 13th July 2025 - 07:35 PM
