| tornik550 |
Aug 24 2010, 08:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have been having issues tuning my carbs. I finally decided to by a wideband air fuel package. I have searched and found several responses. I just want to triple check before I weld the bung. Is the area that is circled a good place to put the bung. I plan on putting it on the front side so it will not be noticeable from the rear- I just didn't have a picture of that side.
| john rogers |
Aug 25 2010, 09:38 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
The comment about on top is correct due to moisture build up. You could also weld a bung on each side just before the collector flange so each side could be read. I used Bosch 3 wire sensors and GM weather seal connectors so the sensor can be unplugged when needed and the 12 volts help the sender heat up very quickly.
tornik550 Is this a good location for a wideband? Aug 24 2010, 08:31 PM
kg6dxn Looks OK. You want it at the merge. The only probl... Aug 24 2010, 08:52 PM
sean_v8_914 go to innovate web site and read o2 sensor install... Aug 24 2010, 09:00 PM
charliew Also put the sensor on the top to keep moisture fr... Aug 24 2010, 09:01 PM
tornik550 Thanks for the great advice Aug 25 2010, 06:49 AM
tomeric914
I used Bosch 3 wire sensors and GM weather seal c... Aug 25 2010, 12:58 PM
kg6dxn
I used Bosch 3 wire sensors and GM weather seal ... Aug 25 2010, 01:33 PM
Cevan I am in the middle of installing a WB myself. I... Aug 25 2010, 12:19 PM
Cupomeat :popcorn: :popcorn:
I am very interested in your... Aug 25 2010, 12:37 PM
Mark Henry
:popcorn: :popcorn:
I am very interested in you... Aug 26 2010, 06:00 AM
charliew
:popcorn: :popcorn:
I am very interested in you... Aug 26 2010, 01:31 PM
jk76.914
:popcorn: :popcorn:
I am very interested in you... Aug 28 2010, 08:12 AM
Elliot Cannon I thought these things were used mainly with compu... Aug 25 2010, 02:02 PM
Cupomeat
I thought these things were used mainly with comp... Aug 25 2010, 02:08 PM
Dr Evil I'll be wiring the one in the bus soon. :popco... Aug 25 2010, 02:30 PM
john rogers The question about needing one with carbs is a goo... Aug 25 2010, 02:42 PM
jk76.914 I've read from a couple of sources that you DO... Aug 26 2010, 04:27 AM
tornik550
I've read from a couple of sources that you D... Aug 26 2010, 06:54 AM
Mark Henry 11 is too rich, best power and cooling on an airco... Aug 26 2010, 02:00 PM
sean_v8_914 the innovate is fast. It can sample each individua... Aug 27 2010, 09:10 PM
Elliot Cannon Looks like I'll be looking for one of these wi... Aug 28 2010, 12:20 AM
Mark Henry
Looks like I'll be looking for one of these w... Aug 28 2010, 08:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:01 AM |
