> Is this a good location for a wideband?
tornik550
post Aug 24 2010, 08:31 PM
I have been having issues tuning my carbs. I finally decided to by a wideband air fuel package. I have searched and found several responses. I just want to triple check before I weld the bung. Is the area that is circled a good place to put the bung. I plan on putting it on the front side so it will not be noticeable from the rear- I just didn't have a picture of that side.
Cupomeat
post Aug 25 2010, 12:37 PM
missing my NY 914 in VA
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
I am very interested in your collective experience as I see VERY unusual results from my WB O2 from Innovate;
In a 1.9l L-jet motor with about 8.6 to 1 CR I get the following results from the Innovate display;
Idle - 22
Mid range (mid throttle) - 14
Full throttle - 8
Now, the car runs very well, so these reading don't make any sense?
Any clue as to what I did wrong?
My O2 sensor is mounted at the 3o'clock position so it is not optimal, but not bad.
jk76.914
post Aug 28 2010, 08:12 AM
QUOTE(Cupomeat @ Aug 25 2010, 02:37 PM) *
Idle - 22
Full throttle - 8
What kind of exhaust, and where is the sensor located? Specifically, is it too close to the tailpipe? If you read the article I posted earlier Attached File  lsuinstal.pdf ( 205.15k ) Number of downloads: 675
, it says that too close to the tailpipe and you may read lean at idle due to air being sucked in between pulses when the pressure can actually drop below atomspheric. They recommend 20" as a starting point, otherwise ignor the idle readings.
tornik550   Is this a good location for a wideband?   Aug 24 2010, 08:31 PM
kg6dxn   Looks OK. You want it at the merge. The only probl...   Aug 24 2010, 08:52 PM
sean_v8_914   go to innovate web site and read o2 sensor install...   Aug 24 2010, 09:00 PM
charliew   Also put the sensor on the top to keep moisture fr...   Aug 24 2010, 09:01 PM
tornik550   Thanks for the great advice   Aug 25 2010, 06:49 AM
john rogers   The comment about on top is correct due to moistur...   Aug 25 2010, 09:38 AM
tomeric914   I used Bosch 3 wire sensors and GM weather seal c...   Aug 25 2010, 12:58 PM
kg6dxn   I used Bosch 3 wire sensors and GM weather seal ...   Aug 25 2010, 01:33 PM
Cevan   I am in the middle of installing a WB myself. I...   Aug 25 2010, 12:19 PM
Cupomeat   :popcorn: :popcorn: I am very interested in your...   Aug 25 2010, 12:37 PM
Mark Henry   :popcorn: :popcorn: I am very interested in you...   Aug 26 2010, 06:00 AM
charliew   :popcorn: :popcorn: I am very interested in you...   Aug 26 2010, 01:31 PM
jk76.914   :popcorn: :popcorn: I am very interested in you...   Aug 28 2010, 08:12 AM
Elliot Cannon   I thought these things were used mainly with compu...   Aug 25 2010, 02:02 PM
Cupomeat   I thought these things were used mainly with comp...   Aug 25 2010, 02:08 PM
Dr Evil   I'll be wiring the one in the bus soon. :popco...   Aug 25 2010, 02:30 PM
john rogers   The question about needing one with carbs is a goo...   Aug 25 2010, 02:42 PM
jk76.914   I've read from a couple of sources that you DO...   Aug 26 2010, 04:27 AM
tornik550   I've read from a couple of sources that you D...   Aug 26 2010, 06:54 AM
Mark Henry   11 is too rich, best power and cooling on an airco...   Aug 26 2010, 02:00 PM
sean_v8_914   the innovate is fast. It can sample each individua...   Aug 27 2010, 09:10 PM
Elliot Cannon   Looks like I'll be looking for one of these wi...   Aug 28 2010, 12:20 AM
Mark Henry   Looks like I'll be looking for one of these w...   Aug 28 2010, 08:14 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:04 AM
