> What Spring rate?, My 100# springs are on backorder...
What Springs would you use?
What spring rate for the rear?
140# [ 16 ] ** [80.00%]
90# [ 2 ] ** [10.00%]
Stock [ 2 ] ** [10.00%]
Total Votes: 20
Guests cannot vote
bmtrnavsky
post Aug 30 2010, 08:10 PM
I ordered some 100# rear springs for my 73 2.0 and just found out they were on back order. My stock springs are toast... Everyone always says WOW! you set that up really squatty in the rear, and I'm like ya the springs are toast... so I was planning on putting in some 100# springs with Boge shocks. The fronts are done now and it is a BIG improvement already, but I have been waiting on my rear springs to do my rear shocks all at once. I don't really want to wait until October to finish this job, so my choices seem to be a stock spring... I don't really want this, a 90# at factory ride height, 140# lowered 1.5 inches, or the stock 65# spring. At this point I realize ANYTHING is better than what I have... but I am leaning towards the 140# springs.
I commute in the car on nice days but the car is mostly driven for fun, and I REALLY want to start taking it to the track for AX. I thought the 100# was a nice balance in performance and ride... is the 140 pound going to ride too harsh on the road?
I guess it's subjective, but I don't want to ruin it's manners on the road where it spends 90% of it's time. But I also want the car to handle really well and I get that I will have to make some compromise.
Thoughts?
SLITS
post Aug 30 2010, 08:53 PM
"This Utah shit is HARSH!"
Far as I remember, 90 - 100 lbs was stock.
Oh well ......
Tom_T
post Aug 30 2010, 10:00 PM
TMI....
QUOTE(SLITS @ Aug 30 2010, 07:53 PM) *
Oh well ......
Stock rear on the 73 2L was 100#
140# would be pretty harsh for a DD unless you have a short commute or well padded butt! (IMG:style_emoticons/default/biggrin.gif)
100# should be stiff enough with good shocks for street fun, but maybe 120# for AX.
Boge shocks are the baseline stock set-up & not very stiff, & I hear their newer HD ones aren't much better. That's why Porsche offered the Bilstein option from the factory. You can still get Bilsteins & front inserts for the Boge Struts, as well as same for Koni's. They recco getting all 4 corners the same mfgr., type & stiffness at the same time - so you'll want to do the front inserts too.
A lot of folks don't like the KYB's - esp. with a street car/DD use.
Back in the day I upgraded to these rear Koni Reds (similar to their street HD ones now, but called "Super D" back then) F & R when my Boges wore out, & they gave a good deal of handling improvement over the Boges IMHO -
BTW - your stock 16mm F & 15mm R factory sway bars should be fine for street & street class AX, but you may want to go through & re-bush everything on the F & R suspension while you're in there upgrading stuff, if they've never been redone in 37-38 years. If you need new tie rod ends/ball joints up front, then you may as well go with the Turbo Tie rod kit for a few bucks more, but stick with the OEM Lemforder kit - not the cheaper & lower quality aftermarket tir rod ends/bj's - cuz I thought they were (IMG:style_emoticons/default/stromberg.gif) & sent them back & just paid the extra for the OEM ones in the other kit (PP, AA, Pelican, maybe PMB & others carry it).
Go forth & drive young Jed-eye!
bmtrnavsky   What Spring rate?   Aug 30 2010, 08:10 PM
SLITS   Far as I remember, 90 - 100 lbs was stock. Oh wel...   Aug 30 2010, 08:53 PM
bmtrnavsky   Far as I remember, 90 - 100 lbs was stock. Oh we...   Aug 30 2010, 08:56 PM
Tom_T   Far as I remember, 90 - 100 lbs was stock. Oh we...   Aug 30 2010, 10:00 PM
SLITS   140s on the rear are a bit stiff, but not that bad...   Aug 30 2010, 09:01 PM
bmtrnavsky   140s on the rear are a bit stiff, but not that ba...   Aug 30 2010, 09:04 PM
SLITS   140s on the rear are a bit stiff, but not that b...   Aug 30 2010, 09:17 PM
Tom_T   140s on the rear are a bit stiff, but not that b...   Aug 30 2010, 10:04 PM
DanT   every 914 (5 of them)I have ever owned has had at ...   Aug 30 2010, 09:06 PM
DanT   Phoenix Red #5 21 mm front bars, 180# rear spring...   Aug 30 2010, 09:11 PM
kg6dxn   I run 200# progressive rate springs. Going down th...   Aug 30 2010, 09:26 PM
Krieger   I run stock front torsion and 140# rear with koni ...   Aug 30 2010, 09:53 PM
DanT   Tom, have you ever owned or driven for any appreci...   Aug 30 2010, 10:06 PM
Andyrew   Hell I have 275's on koni yellows on my car an...   Aug 30 2010, 10:12 PM
bmtrnavsky   I don't think I can return the fronts because ...   Aug 31 2010, 01:29 AM
nsr-jamie   How about some of those progressive rate springs t...   Aug 31 2010, 06:43 AM
dr914@autoatlanta.com   140 will lower the car and make the tail happy, me...   Aug 31 2010, 08:03 AM
bmtrnavsky   140 will lower the car and make the tail happy, m...   Aug 31 2010, 10:06 AM
windforfun   [quote name='dr914@autoatlanta.com' post='1363909...   Aug 31 2010, 01:51 PM
Nürburg Nomad   [quote name='dr914@autoatlanta.com' post='1363909...   Aug 31 2010, 01:56 PM
bmtrnavsky   [quote name='dr914@autoatlanta.com' post='136390...   Aug 31 2010, 06:09 PM
dr914@autoatlanta.com   update we will have the 100 adn 140 springs landed...   Sep 1 2010, 04:22 PM
ConeDodger   I am tripping over a pair of 100# stockers in my g...   Sep 1 2010, 11:29 PM
- Lo-Fi Version Time is now: 15th June 2026 - 02:44 AM
