| draganc |
Aug 30 2010, 11:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi guys!
I’m planning to upgrade my D-jet system on a 75 2.0 (2056) with a MegaSquirt system. I’m still debating how to mount the trigger-wheel-sensor and would like to see some of your solutions. Thank you for your input, Dragan |
| dr914@autoatlanta.com |
Aug 31 2010, 03:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,240 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
We took a new 009 distributor and designed a pickup for it. Works perfectly but very expensive as we had to machine parts to make this functional and reliable. the best thing though is that it uses the original distributor hole so there is no need to machine anything nor drop the engine
Mcmarks is a very economical solution. Hi guys! I’m planning to upgrade my D-jet system on a 75 2.0 (2056) with a MegaSquirt system. I’m still debating how to mount the trigger-wheel-sensor and would like to see some of your solutions. Thank you for your input, Dragan |
| JamesM |
Aug 31 2010, 06:21 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,247 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I had an idea for something similar to this but unfortinatly i lack the manufacturing resources at this point in time to accomplish it.
I wanted to put it where the d-jet injector triggers go though in order to pull the tach signal though a stock wiring harness. I think i have seen an aftermarket wasted spark setup for VW's that uses a similar sensor on top of the distributor setup to the one you have come up with. I will have to see if i can locate it. We took a new 009 distributor and designed a pickup for it. Works perfectly but very expensive as we had to machine parts to make this functional and reliable. the best thing though is that it uses the original distributor hole so there is no need to machine anything nor drop the engine Mcmarks is a very economical solution. Hi guys! I’m planning to upgrade my D-jet system on a 75 2.0 (2056) with a MegaSquirt system. I’m still debating how to mount the trigger-wheel-sensor and would like to see some of your solutions. Thank you for your input, Dragan |
draganc MegaSquirt trigger wheel sensor solution Aug 30 2010, 11:16 PM
McMark My design is available here.
http://www.914world.... Aug 30 2010, 11:24 PM
hcdmueller I bought the McMark trigger wheel. It fits perfec... Aug 31 2010, 01:55 AM
SLKWrx I've got the same setup and the fit/finish is ... Aug 31 2010, 06:57 AM
draganc I will go with Van's design (2nd pic from the ... Aug 31 2010, 07:36 AM
McMark The only change in the final sensor mount is that ... Aug 31 2010, 09:58 AM
draganc
The only change in the final sensor mount is that... Aug 31 2010, 02:11 PM
McMark My newest shipment of wheels is shipping right now... Aug 31 2010, 03:08 PM
draganc
We took a new 009 distributor and designed a pick... Aug 31 2010, 03:45 PM
underthetire
We took a new 009 distributor and designed a pic... Aug 31 2010, 03:48 PM
JamesM
Ya, inquiring minds want to know. I'd love to... Aug 31 2010, 06:11 PM
dr914@autoatlanta.com here is a picture: Aug 31 2010, 03:55 PM
JamesM
here is a picture:
I knew i had seen something ... Aug 31 2010, 08:00 PM
dr914@autoatlanta.com we had all kinds of problems modifying both the fl... Aug 31 2010, 04:01 PM
RJMII McMark's also turns at the rate of the crank..... Aug 31 2010, 04:01 PM
McMark's also turns at the rate of the crank.... Aug 31 2010, 04:08 PM
Jake Raby I am doing some MS test work now.. I ended up usin... Aug 31 2010, 04:05 PM
RJMII
I am doing some MS test work now.. I ended up usi... Aug 31 2010, 04:14 PM
Jake Raby
I am doing some MS test work now.. I ended up us... Aug 31 2010, 06:52 PM
904svo
[quote name='RJMII' post='1364119' date='Aug 31 2... Aug 31 2010, 07:30 PM
JamesM
[quote name='RJMII' post='1364119' date='Aug 31 2... Aug 31 2010, 07:49 PM
JamesM
I am doing some MS test work now.. I ended up usi... Aug 31 2010, 06:50 PM
dr914@autoatlanta.com Jake is the man for all of this stuff. I am excit... Aug 31 2010, 05:20 PM
904svo MS1 extra will let you change the 12x12 AFR1 table... Aug 31 2010, 07:57 PM
JamesM
MS1 extra will let you change the 12x12 AFR1 tabl... Sep 1 2010, 12:02 AM
Jake Raby We haven't seen any benefits of sequential on ... Aug 31 2010, 08:02 PM
JamesM
We haven't seen any benefits of sequential on... Aug 31 2010, 09:01 PM
draganc I like where this discussion is heading!
Jus... Aug 31 2010, 08:46 PM
Jake Raby I actually prefer the handheld programmer of SDS a... Aug 31 2010, 09:10 PM
JamesM
BTW- The theory you have read concerning sequenti... Aug 31 2010, 11:07 PM
DNHunt
Here are my experiences with MS failures. I had ... Sep 1 2010, 07:10 AM
JamesM
Here are my experiences with MS failures. I had... Sep 1 2010, 11:42 AM
Jake Raby
I'd rather take a personal injury as burn th... Sep 1 2010, 08:26 AM
904svo Here's my 36 tooth wheel design mounted with A... Sep 1 2010, 08:29 AM
draganc
Here's my 36 tooth wheel design mounted with ... Sep 2 2010, 07:50 AM
904svo
Here's my 36 tooth wheel design mounted with... Sep 2 2010, 08:19 AM
draganc
[quote name='draganc' post='1364931' date='Sep 2 ... Sep 2 2010, 05:12 PM
904svo
[quote name='draganc' post='1364931' date='Sep 2... Sep 3 2010, 07:52 AM
draganc It's was the only way I could do when running ... Sep 3 2010, 11:41 AM
Mark Henry I've only had two issues with my SDS, the firs... Sep 1 2010, 08:30 AM
Jake Raby The guys at SDS don't like ITBs because they h... Sep 1 2010, 10:18 AM
Jake Raby I bought as much as possible from DIYautotune, bec... Sep 1 2010, 04:19 PM
charliew The db-37 connector was the main reason I put off ... Sep 1 2010, 08:30 PM
JamesM Changing the db-37 out on a stock board is probabl... Sep 3 2010, 12:49 AM
charliew If I changed the connector my idea was to connect ... Sep 4 2010, 08:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 02:50 AM |
