| draganc |
Aug 30 2010, 11:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi guys!
I’m planning to upgrade my D-jet system on a 75 2.0 (2056) with a MegaSquirt system. I’m still debating how to mount the trigger-wheel-sensor and would like to see some of your solutions. Thank you for your input, Dragan |
| dr914@autoatlanta.com |
Aug 31 2010, 03:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,240 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| JamesM |
Aug 31 2010, 08:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,247 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I knew i had seen something similar I saw this compufire DIS-IX system on a 914 once http://www.compufire.com/vw-products-main.html and found another similar system online http://www.compu-tronix.com/DIS4009.htm I am assuming these only have 4 trigger points though. George, How many trigger points are you running and did you gear it to run at crank speed? |
draganc MegaSquirt trigger wheel sensor solution Aug 30 2010, 11:16 PM
McMark My design is available here.
http://www.914world.... Aug 30 2010, 11:24 PM
hcdmueller I bought the McMark trigger wheel. It fits perfec... Aug 31 2010, 01:55 AM
SLKWrx I've got the same setup and the fit/finish is ... Aug 31 2010, 06:57 AM
draganc I will go with Van's design (2nd pic from the ... Aug 31 2010, 07:36 AM
McMark The only change in the final sensor mount is that ... Aug 31 2010, 09:58 AM
draganc
The only change in the final sensor mount is that... Aug 31 2010, 02:11 PM
McMark My newest shipment of wheels is shipping right now... Aug 31 2010, 03:08 PM
dr914@autoatlanta.com We took a new 009 distributor and designed a picku... Aug 31 2010, 03:20 PM
draganc
We took a new 009 distributor and designed a pick... Aug 31 2010, 03:45 PM
underthetire
We took a new 009 distributor and designed a pic... Aug 31 2010, 03:48 PM
JamesM
Ya, inquiring minds want to know. I'd love to... Aug 31 2010, 06:11 PM
JamesM I had an idea for something similar to this but un... Aug 31 2010, 06:21 PM
dr914@autoatlanta.com we had all kinds of problems modifying both the fl... Aug 31 2010, 04:01 PM
RJMII McMark's also turns at the rate of the crank..... Aug 31 2010, 04:01 PM
McMark's also turns at the rate of the crank.... Aug 31 2010, 04:08 PM
Jake Raby I am doing some MS test work now.. I ended up usin... Aug 31 2010, 04:05 PM
RJMII
I am doing some MS test work now.. I ended up usi... Aug 31 2010, 04:14 PM
Jake Raby
I am doing some MS test work now.. I ended up us... Aug 31 2010, 06:52 PM
904svo
[quote name='RJMII' post='1364119' date='Aug 31 2... Aug 31 2010, 07:30 PM
JamesM
[quote name='RJMII' post='1364119' date='Aug 31 2... Aug 31 2010, 07:49 PM
JamesM
I am doing some MS test work now.. I ended up usi... Aug 31 2010, 06:50 PM
dr914@autoatlanta.com Jake is the man for all of this stuff. I am excit... Aug 31 2010, 05:20 PM
904svo MS1 extra will let you change the 12x12 AFR1 table... Aug 31 2010, 07:57 PM
JamesM
MS1 extra will let you change the 12x12 AFR1 tabl... Sep 1 2010, 12:02 AM
Jake Raby We haven't seen any benefits of sequential on ... Aug 31 2010, 08:02 PM
JamesM
We haven't seen any benefits of sequential on... Aug 31 2010, 09:01 PM
draganc I like where this discussion is heading!
Jus... Aug 31 2010, 08:46 PM
Jake Raby I actually prefer the handheld programmer of SDS a... Aug 31 2010, 09:10 PM
JamesM
BTW- The theory you have read concerning sequenti... Aug 31 2010, 11:07 PM
DNHunt
Here are my experiences with MS failures. I had ... Sep 1 2010, 07:10 AM
JamesM
Here are my experiences with MS failures. I had... Sep 1 2010, 11:42 AM
Jake Raby
I'd rather take a personal injury as burn th... Sep 1 2010, 08:26 AM
904svo Here's my 36 tooth wheel design mounted with A... Sep 1 2010, 08:29 AM
draganc
Here's my 36 tooth wheel design mounted with ... Sep 2 2010, 07:50 AM
904svo
Here's my 36 tooth wheel design mounted with... Sep 2 2010, 08:19 AM
draganc
[quote name='draganc' post='1364931' date='Sep 2 ... Sep 2 2010, 05:12 PM
904svo
[quote name='draganc' post='1364931' date='Sep 2... Sep 3 2010, 07:52 AM
draganc It's was the only way I could do when running ... Sep 3 2010, 11:41 AM
Mark Henry I've only had two issues with my SDS, the firs... Sep 1 2010, 08:30 AM
Jake Raby The guys at SDS don't like ITBs because they h... Sep 1 2010, 10:18 AM
Jake Raby I bought as much as possible from DIYautotune, bec... Sep 1 2010, 04:19 PM
charliew The db-37 connector was the main reason I put off ... Sep 1 2010, 08:30 PM
JamesM Changing the db-37 out on a stock board is probabl... Sep 3 2010, 12:49 AM
charliew If I changed the connector my idea was to connect ... Sep 4 2010, 08:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 02:53 AM |
