> MegaSquirt trigger wheel sensor solution, What's your design??
draganc
post Aug 30 2010, 11:16 PM
Hi guys!
I’m planning to upgrade my D-jet system on a 75 2.0 (2056) with a MegaSquirt system.
I’m still debating how to mount the trigger-wheel-sensor and would like to see some of your solutions.
Thank you for your input,
Dragan
DNHunt
post Sep 1 2010, 07:10 AM
914 Wizard? No way. I got too much to learn.
Trust me, I really don't want to have to screw withMS, because I still have scars from it.
Here are my experiences with MS failures. I had 2 failures with wires coming loose because of solder failures at the DB 37 connectors to the Megasquirt board. Both times I was stranded. I had 1 injector driver go up in smoke on an MS1 board but that was in the garage and I hooked stuff up wrong.
And, I had the king of all failures on Jake's dyno where I could not get a tach signal for some unknown reason. When he said he has the scars from it, he's telling the truth. He got some nasty burns on his hands. He grabbed a 12 gauge wire we ran from the battery that shorted to ground on the dyno. His fast thinking and action may have saved all of us from going up as the wire ran across fuel lines. I hate to remember it, that was a really bad day. I never did look for what caused the problem, cause I never unpacked the MS I shipped back home.
That system is only as good as the builder and installer. I think the the weakness is all the soldering and the hodgepodge of used parts people use.
Since then I have run SDS. It is OK for the most part. I don't like the tuning module/ screen. I miss tuning on the PC. It is simple for sure. I had problems at altitude at Tahoe for WCR where it over compensated for elevation gain and ran lean. I had to bump the fueling by using the tuning knob. I also had starting problems that disappeared when we got back down the hill. The acceleration enrichment has been impossible to tune and I live with a bogging down at really low rpm. I'm not often down there but, on the occasional AX course it is a pain cause it forces 2 extra shifts. I would say it is a pretty good electrical carb.
Dave
draganc   MegaSquirt trigger wheel sensor solution   Aug 30 2010, 11:16 PM
McMark   My design is available here. http://www.914world....   Aug 30 2010, 11:24 PM
hcdmueller   I bought the McMark trigger wheel. It fits perfec...   Aug 31 2010, 01:55 AM
SLKWrx   I've got the same setup and the fit/finish is ...   Aug 31 2010, 06:57 AM
draganc   I will go with Van's design (2nd pic from the ...   Aug 31 2010, 07:36 AM
McMark   The only change in the final sensor mount is that ...   Aug 31 2010, 09:58 AM
draganc   The only change in the final sensor mount is that...   Aug 31 2010, 02:11 PM
McMark   My newest shipment of wheels is shipping right now...   Aug 31 2010, 03:08 PM
dr914@autoatlanta.com   We took a new 009 distributor and designed a picku...   Aug 31 2010, 03:20 PM
draganc   We took a new 009 distributor and designed a pick...   Aug 31 2010, 03:45 PM
underthetire   We took a new 009 distributor and designed a pic...   Aug 31 2010, 03:48 PM
JamesM   Ya, inquiring minds want to know. I'd love to...   Aug 31 2010, 06:11 PM
JamesM   I had an idea for something similar to this but un...   Aug 31 2010, 06:21 PM
dr914@autoatlanta.com   here is a picture:   Aug 31 2010, 03:55 PM
JamesM   here is a picture: I knew i had seen something ...   Aug 31 2010, 08:00 PM
dr914@autoatlanta.com   we had all kinds of problems modifying both the fl...   Aug 31 2010, 04:01 PM
RJMII   McMark's also turns at the rate of the crank.....   Aug 31 2010, 04:01 PM
dr914@autoatlanta.com   McMark's also turns at the rate of the crank....   Aug 31 2010, 04:08 PM
Jake Raby   I am doing some MS test work now.. I ended up usin...   Aug 31 2010, 04:05 PM
RJMII   I am doing some MS test work now.. I ended up usi...   Aug 31 2010, 04:14 PM
Jake Raby   I am doing some MS test work now.. I ended up us...   Aug 31 2010, 06:52 PM
904svo   [quote name='RJMII' post='1364119' date='Aug 31 2...   Aug 31 2010, 07:30 PM
JamesM   [quote name='RJMII' post='1364119' date='Aug 31 2...   Aug 31 2010, 07:49 PM
JamesM   I am doing some MS test work now.. I ended up usi...   Aug 31 2010, 06:50 PM
dr914@autoatlanta.com   Jake is the man for all of this stuff. I am excit...   Aug 31 2010, 05:20 PM
904svo   MS1 extra will let you change the 12x12 AFR1 table...   Aug 31 2010, 07:57 PM
JamesM   MS1 extra will let you change the 12x12 AFR1 tabl...   Sep 1 2010, 12:02 AM
Jake Raby   We haven't seen any benefits of sequential on ...   Aug 31 2010, 08:02 PM
JamesM   We haven't seen any benefits of sequential on...   Aug 31 2010, 09:01 PM
draganc   I like where this discussion is heading! Jus...   Aug 31 2010, 08:46 PM
Jake Raby   I actually prefer the handheld programmer of SDS a...   Aug 31 2010, 09:10 PM
JamesM   BTW- The theory you have read concerning sequenti...   Aug 31 2010, 11:07 PM
DNHunt   Here are my experiences with MS failures. I had ...   Sep 1 2010, 07:10 AM
JamesM   Here are my experiences with MS failures. I had...   Sep 1 2010, 11:42 AM
Jake Raby   I'd rather take a personal injury as burn th...   Sep 1 2010, 08:26 AM
904svo   Here's my 36 tooth wheel design mounted with A...   Sep 1 2010, 08:29 AM
draganc   Here's my 36 tooth wheel design mounted with ...   Sep 2 2010, 07:50 AM
904svo   Here's my 36 tooth wheel design mounted with...   Sep 2 2010, 08:19 AM
draganc   [quote name='draganc' post='1364931' date='Sep 2 ...   Sep 2 2010, 05:12 PM
904svo   [quote name='draganc' post='1364931' date='Sep 2...   Sep 3 2010, 07:52 AM
draganc   It's was the only way I could do when running ...   Sep 3 2010, 11:41 AM
Mark Henry   I've only had two issues with my SDS, the firs...   Sep 1 2010, 08:30 AM
Jake Raby   The guys at SDS don't like ITBs because they h...   Sep 1 2010, 10:18 AM
Jake Raby   I bought as much as possible from DIYautotune, bec...   Sep 1 2010, 04:19 PM
charliew   The db-37 connector was the main reason I put off ...   Sep 1 2010, 08:30 PM
JamesM   Changing the db-37 out on a stock board is probabl...   Sep 3 2010, 12:49 AM
charliew   If I changed the connector my idea was to connect ...   Sep 4 2010, 08:42 AM
- Lo-Fi Version Time is now: 15th June 2026 - 03:20 AM
