External Oil Cooler, let me see some pictures |
tradisrad |
Jun 22 2010, 11:03 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
bugsy0 |
Sep 1 2010, 11:28 AM
Member Group: Members Posts: 191 Joined: 26-July 06 Member No.: 6,508 Region Association: None |
realred914 - so what I hear you saying is I can get effective cooling using a horizontally mounted unit - eliminates much of the risk of damage from debris. sounds good - thanks.
now can I get away w/ a horizontal mount and no fan to make it even simpler? |
realred914 |
Sep 2 2010, 08:09 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
realred914 - so what I hear you saying is I can get effective cooling using a horizontally mounted unit - eliminates much of the risk of damage from debris. sounds good - thanks. now can I get away w/ a horizontal mount and no fan to make it even simpler? we found the fan is needed on extended drvies to get to the target temp of 180F. without the fan, we'd hit near 200F -210F an improvement over no cooler, but not good enough. just follow tradisrads project on this post, he has photos of the set up above the transmission, 72 plate cooler with a six inch fan. stay cool! |
Lo-Fi Version | Time is now: 9th June 2024 - 10:49 PM |
