| draganc |
Aug 30 2010, 11:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi guys!
I’m planning to upgrade my D-jet system on a 75 2.0 (2056) with a MegaSquirt system. I’m still debating how to mount the trigger-wheel-sensor and would like to see some of your solutions. Thank you for your input, Dragan |
| charliew |
Sep 4 2010, 08:42 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
If I changed the connector my idea was to connect to the leads already in the holes and cut them off the back of the connector and only do the higher amp ones and leave the db-37 for the other original stuff.
It sounds like I need to leave it alone and just see what you come up with. I'm in no rush. I did check out the board and look at the solder joints with a magnyfing glass and it is a ver3. I'm a little concerned that the pot has been turned too far though as I tried to turn it a few turns gently and never felt a stop. I think I remember it may be a 10 turn pot and maybe I just didn't turn it far enough but I didn't want to push my luck until I do a little more research. For me sequential would only be beneficial on a high reving motor with a plenum and long runners with a egt on each exhaust port. Subys are bad about port 4 I think getting lean, thats the one that has more piston failures, but 3 seems to be the hottest and thats on a watercooled motor. |
draganc MegaSquirt trigger wheel sensor solution Aug 30 2010, 11:16 PM
McMark My design is available here.
http://www.914world.... Aug 30 2010, 11:24 PM
hcdmueller I bought the McMark trigger wheel. It fits perfec... Aug 31 2010, 01:55 AM
SLKWrx I've got the same setup and the fit/finish is ... Aug 31 2010, 06:57 AM
draganc I will go with Van's design (2nd pic from the ... Aug 31 2010, 07:36 AM
McMark The only change in the final sensor mount is that ... Aug 31 2010, 09:58 AM
draganc
The only change in the final sensor mount is that... Aug 31 2010, 02:11 PM
McMark My newest shipment of wheels is shipping right now... Aug 31 2010, 03:08 PM
dr914@autoatlanta.com We took a new 009 distributor and designed a picku... Aug 31 2010, 03:20 PM
draganc
We took a new 009 distributor and designed a pick... Aug 31 2010, 03:45 PM
underthetire
We took a new 009 distributor and designed a pic... Aug 31 2010, 03:48 PM
JamesM
Ya, inquiring minds want to know. I'd love to... Aug 31 2010, 06:11 PM
JamesM I had an idea for something similar to this but un... Aug 31 2010, 06:21 PM
dr914@autoatlanta.com here is a picture: Aug 31 2010, 03:55 PM
JamesM
here is a picture:
I knew i had seen something ... Aug 31 2010, 08:00 PM
dr914@autoatlanta.com we had all kinds of problems modifying both the fl... Aug 31 2010, 04:01 PM
RJMII McMark's also turns at the rate of the crank..... Aug 31 2010, 04:01 PM
McMark's also turns at the rate of the crank.... Aug 31 2010, 04:08 PM
Jake Raby I am doing some MS test work now.. I ended up usin... Aug 31 2010, 04:05 PM
RJMII
I am doing some MS test work now.. I ended up usi... Aug 31 2010, 04:14 PM
Jake Raby
I am doing some MS test work now.. I ended up us... Aug 31 2010, 06:52 PM
904svo
[quote name='RJMII' post='1364119' date='Aug 31 2... Aug 31 2010, 07:30 PM
JamesM
[quote name='RJMII' post='1364119' date='Aug 31 2... Aug 31 2010, 07:49 PM
JamesM
I am doing some MS test work now.. I ended up usi... Aug 31 2010, 06:50 PM
dr914@autoatlanta.com Jake is the man for all of this stuff. I am excit... Aug 31 2010, 05:20 PM
904svo MS1 extra will let you change the 12x12 AFR1 table... Aug 31 2010, 07:57 PM
JamesM
MS1 extra will let you change the 12x12 AFR1 tabl... Sep 1 2010, 12:02 AM
Jake Raby We haven't seen any benefits of sequential on ... Aug 31 2010, 08:02 PM
JamesM
We haven't seen any benefits of sequential on... Aug 31 2010, 09:01 PM
draganc I like where this discussion is heading!
Jus... Aug 31 2010, 08:46 PM
Jake Raby I actually prefer the handheld programmer of SDS a... Aug 31 2010, 09:10 PM
JamesM
BTW- The theory you have read concerning sequenti... Aug 31 2010, 11:07 PM
DNHunt
Here are my experiences with MS failures. I had ... Sep 1 2010, 07:10 AM
JamesM
Here are my experiences with MS failures. I had... Sep 1 2010, 11:42 AM
Jake Raby
I'd rather take a personal injury as burn th... Sep 1 2010, 08:26 AM
904svo Here's my 36 tooth wheel design mounted with A... Sep 1 2010, 08:29 AM
draganc
Here's my 36 tooth wheel design mounted with ... Sep 2 2010, 07:50 AM
904svo
Here's my 36 tooth wheel design mounted with... Sep 2 2010, 08:19 AM
draganc
[quote name='draganc' post='1364931' date='Sep 2 ... Sep 2 2010, 05:12 PM
904svo
[quote name='draganc' post='1364931' date='Sep 2... Sep 3 2010, 07:52 AM
draganc It's was the only way I could do when running ... Sep 3 2010, 11:41 AM
Mark Henry I've only had two issues with my SDS, the firs... Sep 1 2010, 08:30 AM
Jake Raby The guys at SDS don't like ITBs because they h... Sep 1 2010, 10:18 AM
Jake Raby I bought as much as possible from DIYautotune, bec... Sep 1 2010, 04:19 PM
charliew The db-37 connector was the main reason I put off ... Sep 1 2010, 08:30 PM
JamesM Changing the db-37 out on a stock board is probabl... Sep 3 2010, 12:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 02:57 AM |
