Help! holes in the bottom of the front trunk, not rust related! |
bradtho |
Sep 5 2010, 06:26 PM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I've got my work light underneath on the left so you can see better. There's a matching set on the right side that aren't lit up. They are shaped like a figure 8 (upside down in this view) meaning that it looks like someone put a small hole in, then decided they needed it bigger and offset. all 4 holes have this same size/shape. First thing, any clue what these were for? Looking underneath, it appears that something was attached underneath, but the cars are so low I can't imagine what was attached. Second, what would you do to plug them? I'm trying to prepare for the return of the rain (this is a DD). I was planning on just using some conical rubber stoppers, but the oblong shape is going to make that a non-starter. I'm afraid any kind of tape will just hold water and be worse than nothing at all. Is nothing at all my best shot? It would be a real shame to let rust get started, it's in such great shape now. |
carr914 |
Sep 5 2010, 09:59 PM
Racer from Birth Group: Members Posts: 119,021 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Geez, how about some used chewing gum (IMG:style_emoticons/default/shades.gif)
Mark Henry |
Sep 5 2010, 10:21 PM
Not sticky enough (IMG:style_emoticons/default/biggrin.gif) Really, what's better if you don't have the time, money or equipment to weld it up proper? Just leave it to hose the trunk? Or put a temporary patch till you have the time or dime to fix it proper. I did this on the wifes bug, big freaking gas heater exhaust hole. I never did fix it proper, lasted 5 years of Canadian winters. The whole bug rusted right out, but the patch (which BTW was directly above the front tire) never failed. |
Lo-Fi Version | Time is now: 9th June 2024 - 02:21 PM |
