> 1.7L still running terribly, $1800 and a month in the shop yields a barely drivable teener
BCinSC
post Sep 7 2010, 01:47 PM
Nothing but Trouble
rough running
stalls at idle
backfires
0-50 takes several minutes (notice I didn't say 60 - can't hit that)
strong smell of raw gas
all speaks to at least one cylinder not firing
No visible signs of leaking fuel.
2 new injectors don't seem to have helped
Trigger and Ignition points replaced
Ignition wires checked and rechecked
Timing was supposedly set, but will check myself when I get home.
Why is this thing so cranky?
BCinSC
post Sep 7 2010, 02:09 PM
Nothing but Trouble
I called Autobahn this morning, after the white knuckle drive into work, and let Mike know how disappointed I was.
BCinSC   1.7L still running terribly   Sep 7 2010, 01:47 PM
7TPorsh   Firing order?   Sep 7 2010, 01:57 PM
djm914-6   All that time and money and it still isn't rig...   Sep 7 2010, 01:58 PM
BCinSC   I called Autobahn this morning, after the white kn...   Sep 7 2010, 02:09 PM
BCinSC   Thing is, initial cold start seems OK. As it warm...   Sep 7 2010, 02:10 PM
Root_Werks   Thing is, initial cold start seems OK. As it war...   Sep 7 2010, 03:31 PM
Bartlett 914   rough running stalls at idle backfires 0-50 takes...   Sep 7 2010, 02:38 PM
Root_Werks   Wow, This sounds like a simple fix. Already ment...   Sep 7 2010, 03:30 PM
BCinSC   Work done at reputable shop CHT - replaced <20...   Sep 8 2010, 05:28 AM
76-914   Work done at reputable shop CHT - replaced <2...   Sep 8 2010, 08:19 AM
Lennies914   AAR= auxilary air regulator. Open when cold, close...   Sep 8 2010, 07:20 AM
trent1542   maybe your timing is off?   Sep 8 2010, 08:50 AM
Root_Werks   maybe your timing is off? Yup, could be that, v...   Sep 8 2010, 08:54 AM
trent1542   maybe your timing is off? Yup, could be that, ...   Sep 8 2010, 09:50 AM
vsg914   [quote name='Root_Werks' post='1367714' date='Sep...   Sep 8 2010, 10:15 AM
trent1542   [quote name='Root_Werks' post='1367714' date='Se...   Sep 8 2010, 04:57 PM
jk76.914   ruptured MPS? Have you checked to see if it holds...   Sep 8 2010, 05:08 PM
Cevan   What service did the shop perform for the $18...   Sep 8 2010, 06:49 PM
scotty b   Take the intake manifold off and look for a 3 way ...   Sep 8 2010, 06:53 PM
scotty b   B)-->
- Lo-Fi Version Time is now: 9th June 2026 - 03:45 AM
