| sixaddict |
Sep 7 2010, 11:35 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Need a source for decent quality floor jack that will lift at least 23". 914-6 needs to be fairly high and if the car is raised most jacks will not reach bottom of engine. Amazingly all auto parts stores carry jacks that max out at about 20".
Harbor Freight used to have a tall one but it was discontinued. I pulled two engines over the weekend and reinstalled one and I used a rental jack that had me playing games to make it work....hassle and dangerous. Never again .... Thanks for leads Help please ! |
| 914rat |
Sep 8 2010, 03:41 PM
Member ![]() ![]() Group: Members Posts: 280 Joined: 3-July 06 From: Maryland Member No.: 6,362 |
If you are under a car a lot ,a mid rise lift makes it a lot easier on a 53 year old fat guy like me.They run $1500-$2000.Dropping an engine is almost fun.Set the engine on a cradle unbolt and disconnect everything,raise the car and roll out the engine.Makes routine brake jobs,tire rotations,valve adjustments, and oil changes easier too.The only problem is friends and relatives want you to move your project every time they need brakes or an oil change.
| jim_hoyland |
Sep 8 2010, 04:43 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,080 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
If you are under a car a lot ,a mid rise lift makes it a lot easier on a 53 year old fat guy like me.They run $1500-$2000.Dropping an engine is almost fun.Set the engine on a cradle unbolt and disconnect everything,raise the car and roll out the engine.Makes routine brake jobs,tire rotations,valve adjustments, and oil changes easier too.The only problem is friends and relatives want you to move your project every time they need brakes or an oil change. Got a picture of a cradle... (IMG:style_emoticons/default/smile.gif) |
sixaddict Source for high lift floor jack Sep 7 2010, 11:35 AM
bandjoey I use the HF 3ton floor jack. It lifts to 20... Sep 7 2010, 12:06 PM
Mark Henry I got a good used 7000lbs lift for a 1000 bones of... Sep 7 2010, 01:10 PM
Rleog The Bird Board lists a jack by AC Hydraulic that g... Sep 7 2010, 02:03 PM
sixaddict FAct is I just bit the bullet on AC jack...life is... Sep 7 2010, 02:18 PM
pcar916 Here you go!
http://www.pelicanparts.com/cata... Sep 7 2010, 03:31 PM
Vacca Rabite
Here you go!
http://www.pelicanparts.com/cat... Sep 7 2010, 05:14 PM
elmonte Wayne ran this thread in June
http://forums.pelic... Sep 7 2010, 05:37 PM
sixaddict It said unavail;able but sales checked and it wsa... Sep 7 2010, 08:54 PM
StratPlayer Bit spendy, not sure if this is what you had in mi... Sep 8 2010, 09:13 AM
914rat
If you are under a car a lot ,a mid rise lift m... Sep 8 2010, 04:54 PM
sixaddict Jim:
Shoot me your email address..and I will do it... Sep 9 2010, 09:13 AM
Steve Bendpack scissor lift. Best $1500 bucks I ev... Sep 8 2010, 11:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:41 AM |
