 Forum Rules Classified Rules!
> FS: Original 1.7L, Saturn Yellow
mtndawg
post Sep 6 2010, 09:53 PM
Sold
My 914 is (almost) all original with a few improvements. I replaced the sound barrier with improved rubber and the rear trunk rollers are brass. Otherwise it's totally original 1.7L with djet fuel injection. I'm selling because I'm ready to move to a new project. Hopefully I can find someone to appreciate how clean this is. I bought it from the second owner who kept it in his garage and he bought it from the original owner who also garaged it. I have the original sales receipt. Yes...under the rocker panels looks as good as the rest of the car.
$5500
New Rubber fuel lines (correct metric sizes)
New fuel filter
New fuel tank screen (sock)
Like new fuel injectors from Fuel Injection Corp
New fuel pressure regulator
New engine bay rubber
New head temp sensor
New vaccuum hoses (correct metric sizes)
New front and rear main seals
New transmission seal
New valve lifter tube seals
New clutch, throwout bearing, pressure plate
New clutch cable
New bushings on shift linkage
New tires
New rear passenger wheel bearing
Rebuilt rear calipers
Rebuilt pedal assembly
Manifold pressure sensor holds vacuum
Machined flywheel
Engine compartment is clean with no rust
Inside of fuel tank has been treated and is totally clean
Rocker panels are powdercoated
Wheels polished and painted factory silver (Thanks Al Weidman!)
Original Saturn Yellow
Send me a message if you want to look at it or just talk about 914's! I'm in the Sacramento area.
mtndawg
post Sep 8 2010, 06:20 PM
Rust: I replaced the battery tray with a new one because it was rusted. Under the battery I cleaned, etched, sealed the metal with POR15, put seam sealer on the seams and painted. It's perfect. I just wanted to make it as impervious to water as I could. It looks like new around and under the battery. It's always garaged.
Mileage: My odometer doesn't work. I recently took the gauges out and decided I would leave the odometer alone. The guy I bought the car from said he used to see it in a storage unit for years and years when he visited his own storage unit. He asked the original owner how long it had been there in storage and she told him 20 years. I have the registration cards for the 70's and 80's that seem to support that. Yes, I have the first registration card when it was sold new. I've been through every inch of this car and it's very original. The rubber seals on the engine were bad, so I replaced them. It gets 25+ mpg.
Rebuilt: Nothing has been rebuilt to my knowledge. I get about 1 small drop of oil on the garage floor every 2 weeks or so. The engine runs great and transmission shifts smoothly.
- Lo-Fi Version Time is now: 9th June 2026 - 03:25 AM
