> Brakes won't retract...
amphiduck
post Sep 9 2010, 01:44 PM
So I just put all four calipers back on my car, filled the reservoir with fluid and pumped the pedal a few times to see if there were any leaks around the pistons. The system is tight, no leaks anywhere. I started bleeding the pedals in the order given by Haynes, and now all the rotors won't spin because the pistons won't retract and the brake pedal barely moves. What gives? I feel like I'm making a novice mistake somewhere.
Thanks in advance.
amphiduck
post Sep 9 2010, 03:31 PM
All four wheels are extremely difficult to rotate by hand now. Beforehand, The pedal had no pressure and gradually built up pressure through bleeding with the "buddy system". I did see the back left pads move inward towards the rotor while bleeding. And I'm not sure about the pedal push rod being adjusted correctly, the car has been sitting forever. Don't really know even how to make that adjustment.
- Lo-Fi Version Time is now: 9th June 2026 - 03:45 AM
