| amphiduck |
Sep 9 2010, 01:44 PM
Member ![]() ![]() Group: Members Posts: 94 Joined: 29-September 06 From: Tennessee Member No.: 6,947 |
So I just put all four calipers back on my car, filled the reservoir with fluid and pumped the pedal a few times to see if there were any leaks around the pistons. The system is tight, no leaks anywhere. I started bleeding the pedals in the order given by Haynes, and now all the rotors won't spin because the pistons won't retract and the brake pedal barely moves. What gives? I feel like I'm making a novice mistake somewhere.
Thanks in advance. |
| Tom |
Sep 9 2010, 03:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Try opening the bleed valve a small amount on one wheel only and see if pressure bleeds off on that wheel. If it does and the wheel turns more freely, how about the other wheels? If the above wheel turns freely now, you may have the old rubber hose problem, the internal passage swells up and won't let pressure bleed off. If they all turn freely after bleeding only one wheel, you have something wrong with the master cylinder.
Tom |
amphiduck Brakes won't retract... Sep 9 2010, 01:44 PM
dr914@autoatlanta.com
So I just put all four calipers back on my car, f... Sep 9 2010, 02:07 PM
bandjoey Front? Back? All 4? Sep 9 2010, 03:06 PM
messix is the brake pedal push rod adjusted correctly, it... Sep 9 2010, 03:10 PM
amphiduck All four wheels are extremely difficult to rotate ... Sep 9 2010, 03:31 PM
amphiduck Oh and I did not bleed the master cylinder. Not s... Sep 9 2010, 03:32 PM
amphiduck Tom, Thanks for the heads up. I'll go try tha... Sep 9 2010, 03:44 PM
underthetire If you were able to bleed it, doubt it's the p... Sep 9 2010, 04:36 PM
amphiduck I tried opening one of the valves on the right rea... Sep 9 2010, 05:10 PM
amphiduck Not sure if it matters, but the lines in rear are ... Sep 9 2010, 05:16 PM
Tom With the one wheel loose and the others still tigh... Sep 9 2010, 05:24 PM
bandjoey Venting Clearance on the rear too tight and missin... Sep 9 2010, 06:50 PM
Drums66
Venting Clearance on the rear too tight and missi... Sep 10 2010, 11:14 AM
amphiduck Well tonight I put new brake hoses on, hoping that... Sep 9 2010, 10:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 03:44 AM |
