| amphiduck |
Sep 9 2010, 01:44 PM
Member ![]() ![]() Group: Members Posts: 94 Joined: 29-September 06 From: Tennessee Member No.: 6,947 |
So I just put all four calipers back on my car, filled the reservoir with fluid and pumped the pedal a few times to see if there were any leaks around the pistons. The system is tight, no leaks anywhere. I started bleeding the pedals in the order given by Haynes, and now all the rotors won't spin because the pistons won't retract and the brake pedal barely moves. What gives? I feel like I'm making a novice mistake somewhere.
Thanks in advance. |
| amphiduck |
Sep 9 2010, 05:10 PM
I tried opening one of the valves on the right rear caliper, and no brake fluid came out until I pushed the brake pedal. This did allow the rotor to spin freely, but only a very small amount (not sure where it was elbow grease that allowed that or the caliper actually freed up). With that one valve open, all the other wheels were still very tight.
amphiduck Brakes won't retract... Sep 9 2010, 01:44 PM
dr914@autoatlanta.com
So I just put all four calipers back on my car, f... Sep 9 2010, 02:07 PM
bandjoey Front? Back? All 4? Sep 9 2010, 03:06 PM
messix is the brake pedal push rod adjusted correctly, it... Sep 9 2010, 03:10 PM
amphiduck All four wheels are extremely difficult to rotate ... Sep 9 2010, 03:31 PM
amphiduck Oh and I did not bleed the master cylinder. Not s... Sep 9 2010, 03:32 PM
Tom Try opening the bleed valve a small amount on one ... Sep 9 2010, 03:38 PM
amphiduck Tom, Thanks for the heads up. I'll go try tha... Sep 9 2010, 03:44 PM
underthetire If you were able to bleed it, doubt it's the p... Sep 9 2010, 04:36 PM
amphiduck Not sure if it matters, but the lines in rear are ... Sep 9 2010, 05:16 PM
Tom With the one wheel loose and the others still tigh... Sep 9 2010, 05:24 PM
bandjoey Venting Clearance on the rear too tight and missin... Sep 9 2010, 06:50 PM
Drums66
Venting Clearance on the rear too tight and missi... Sep 10 2010, 11:14 AM
amphiduck Well tonight I put new brake hoses on, hoping that... Sep 9 2010, 10:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 03:44 AM |
