Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
This guy redesigned the original MS board to incorporate the relays onto the board and he designed it to be waterproof
This should be perfect for our cars for those that want to mount the ECU in the engine compartment without resorting to tupperware (IMG:style_emoticons/default/smile.gif) MiniMS waterproof and on-board relay Megasquirt |
Mueller |
add a fan to the list...I normally just use a small box fan to suck the fumes away from the workspace.....special fans are available that have a filter.......
another important item: solder sucker for when you need to fix a mistake of too much solder or need to remove a component.... |
Lo-Fi Version | Time is now: 13th July 2025 - 07:17 PM |
