| amphiduck |
Sep 9 2010, 01:44 PM
Member ![]() ![]() Group: Members Posts: 94 Joined: 29-September 06 From: Tennessee Member No.: 6,947 |
So I just put all four calipers back on my car, filled the reservoir with fluid and pumped the pedal a few times to see if there were any leaks around the pistons. The system is tight, no leaks anywhere. I started bleeding the pedals in the order given by Haynes, and now all the rotors won't spin because the pistons won't retract and the brake pedal barely moves. What gives? I feel like I'm making a novice mistake somewhere.
Thanks in advance. |
| bandjoey |
Sep 9 2010, 06:50 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Venting Clearance on the rear too tight and missing the metal 'spacers' for clearance in the front???
amphiduck Brakes won't retract... Sep 9 2010, 01:44 PM
dr914@autoatlanta.com
So I just put all four calipers back on my car, f... Sep 9 2010, 02:07 PM
bandjoey Front? Back? All 4? Sep 9 2010, 03:06 PM
messix is the brake pedal push rod adjusted correctly, it... Sep 9 2010, 03:10 PM
amphiduck All four wheels are extremely difficult to rotate ... Sep 9 2010, 03:31 PM
amphiduck Oh and I did not bleed the master cylinder. Not s... Sep 9 2010, 03:32 PM
Tom Try opening the bleed valve a small amount on one ... Sep 9 2010, 03:38 PM
amphiduck Tom, Thanks for the heads up. I'll go try tha... Sep 9 2010, 03:44 PM
underthetire If you were able to bleed it, doubt it's the p... Sep 9 2010, 04:36 PM
amphiduck I tried opening one of the valves on the right rea... Sep 9 2010, 05:10 PM
amphiduck Not sure if it matters, but the lines in rear are ... Sep 9 2010, 05:16 PM
Tom With the one wheel loose and the others still tigh... Sep 9 2010, 05:24 PM
Drums66
Venting Clearance on the rear too tight and missi... Sep 10 2010, 11:14 AM
amphiduck Well tonight I put new brake hoses on, hoping that... Sep 9 2010, 10:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 03:44 AM |
