> Stock Oil Cooler Testing for leaks, Out of car
jim_hoyland
post Sep 9 2010, 08:58 AM
Get that VIN ?
How is a stock oil cooler tested when not installed ? Any aftermarket cooler preferred ?
bandjoey
post Sep 9 2010, 06:55 PM
bandjoey
Talk to Clay or look for his write up on changing the cooler seals. You can do this without pulling the fan shroud off too. The condensed version of that thread states:
You can get the cooler out without pulling the motor by sliding the cooler forward after removing the nuts and the oil filter mount, and there's about an inch of room. Insert needle nose vice grips and unscrew the 3 studs out...pull the cooler down.
I changed the seals in the car doing this, and it was not hard, so I can see pulling the studs out just another 10 minutes to the job.
- Lo-Fi Version Time is now: 9th June 2026 - 03:44 AM
