Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
This guy redesigned the original MS board to incorporate the relays onto the board and he designed it to be waterproof
This should be perfect for our cars for those that want to mount the ECU in the engine compartment without resorting to tupperware (IMG:style_emoticons/default/smile.gif) MiniMS waterproof and on-board relay Megasquirt |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
I like solder wick and I use it a lot. Use the solder sucker for big blobs. The solder wick helps you clean up leads and traces and get rid of every last drop of excess solder. For removing ICs and components with a lot of leads, solder wick helps a LOT.
Lo-Fi Version | Time is now: 13th July 2025 - 07:50 PM |
