| jeffdon |
Sep 15 2010, 01:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Battery was dead yesterday. Threw a charger on it over night. Putting an ammeter between the pos cable and pos terminal, i show a current drain of 69mA. I have nothing fancy in the car like a stereo or alarm that would draw current with the key off.
Does this amount of current draw sound normal? |
| Tom_T |
Sep 15 2010, 02:38 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
It's also a function of whether you charge it enough when driven to recharge the battery - ie: short trips won't do it & many will run it down low, then sitting does the rest. Try a trickle charger/maintainer if it's not driven much or mostly short hops.
jeffdon Current drain Sep 15 2010, 01:13 PM
underthetire 69 mA is nothing. I think natural discharge rate ... Sep 15 2010, 01:21 PM
jeffdon
69 mA is nothing. I think natural discharge rate... Sep 15 2010, 01:37 PM
underthetire You didn't happen to leave the turn signal lev... Sep 15 2010, 01:56 PM
jeffdon
You didn't happen to leave the turn signal le... Sep 15 2010, 02:00 PM
orange914
Try a trickle charger/maintainer if it's not... Sep 15 2010, 04:37 PM
tradisrad I recently had an optima battery go bad. Less than... Sep 15 2010, 02:44 PM
warrenoliver With your meter connected, remove then replace you... Sep 15 2010, 03:10 PM
jt914-6 Have always had good luck using the Battery Tender... Sep 15 2010, 05:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:12 PM |
