External Oil Cooler, let me see some pictures |
tradisrad |
Jun 22 2010, 11:03 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
brant |
Sep 18 2010, 10:52 AM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
finally doing my install today of the atomic derale.
anyone have pictures of how they routed the oil lines from the cooler to the sandwhich adapter... I have heat exchangers and also J tubes.... not a lot of room up there left to put stuff into - I hate running against the exhaust (heat the oil worse) - on the other hand, I could squeeze by the valve covers, but future valve adjustments will be impossible or at least harder. - I'm considering cutting through the tin and into the engine bay, but don't know where to come back down at to clear everything and hit the sandwhich. - Since the swing arm needs space, I was avoiding it all together, but maybe I can go over it? and then come back from the front? any pictures of routing from folks (especially with stock heat exhchangers, and the stock -4 engine bar) would be great! brant |
Lo-Fi Version | Time is now: 7th June 2024 - 06:59 AM |
