> Copper nuts, exhaust leaks!
mgphoto
post Sep 16 2010, 09:06 PM
"If there is a mistake it will find me"
Hello,
I am having a problem with exhaust leaks, I am, for the first time using copper nuts as opposed to the steel with insert and flange Porsche part # 039.256.297 see photo below.
I would still be using these if I hadn't lost one, and Porsche says these are NLA.
The procedure I would use, after replacing the copper seals, I would use Never Seez on the studs and torque the steel nuts to 16 ft-lbs.
I am not sure if I should use Never Seez with the copper nuts and I am not sure the torque is correct for these fasteners, as they are oval shaped and seem tighter to start with?
Any experience with this would be very helpful.
Thanks,
Mike
Cap'n Krusty
post Sep 17 2010, 02:17 PM
Cap'n Krusty
I agree with Dave (realred). It would be well for everyone to remember that the original Porsche exhaust nuts, both the style used on the 1.7/1.8 cars, and the one specifically for the 2.0 cars, are NOT lock nuts, and were cad plated. All were heli-coiled. Any discussion involving the copper plated lock nuts should take into consideration they're NOT the same. They require different torque on installation because you have to overcome the locking force. The plating changes the effort, as well. I use a little anti-seize on any exhaust fastener, giving it just a little extra torque to compensate for the lessening of the friction.
If I can reuse the original nuts, or dig into the stash of used ones, I do.
The Cap'n
mgphoto
post Sep 17 2010, 04:59 PM
QUOTE(Cap'n Krusty @ Sep 17 2010, 01:17 PM) *
The Cap'n
I can say I had fewer problems when I switched to 2.0L fastener.
Thanks for your input Cap, seems I, like politics, am one nut short of a quorum!
Cap'n Krusty
post Sep 18 2010, 07:58 AM
Cap'n Krusty
QUOTE(mgphoto @ Sep 17 2010, 03:59 PM) *
The Cap'n
It appears I may have a spare one. Since you may not be here for the open house at my shop and GPR (foolish move, that!), maybe someone can pick it up for you. Free will donations accepted. Where are you located?
mgphoto
post Sep 18 2010, 09:41 AM
QUOTE(Cap'n Krusty @ Sep 18 2010, 06:58 AM) *
The Cap'n
Hello Cap,
I am in the Burbank area, I would have been there for the open house but I have to work this weekend. If anyone heads south of Burbank, I am right off the 5 fwy, at the Sunland/Vineland exit.
Mike
Cap'n Krusty
post Sep 18 2010, 07:40 PM
Cap'n Krusty
QUOTE(mgphoto @ Sep 18 2010, 08:41 AM) *
The Cap'n
Hello Cap,
Mike
I'll get it to Pasadena within a few days. PM me your phone number so the guy can call you. It's my ONLY spare, I'm keeping one full set on hand.
The Cap'n
mgphoto   Copper nuts   Sep 16 2010, 09:06 PM
brer   I believe the Porsche nuts are copper plated, not ...   Sep 16 2010, 09:32 PM
Drums66   I believe the Porsche nuts are copper plated, not...   Sep 17 2010, 11:11 AM
SGB   Copper is used so it can be cold chiseled off if t...   Sep 16 2010, 10:35 PM
mgphoto   Copper is used so it can be cold chiseled off if ...   Sep 17 2010, 12:37 AM
avidfanjpl   Hey I used gasket cement, but superglue is good to...   Sep 17 2010, 01:22 AM
Van   Copper coated. You can get them from NAPA for abo...   Sep 17 2010, 05:25 AM
realred914   i'd still go with the specified torque as poin...   Sep 17 2010, 10:49 AM
mgphoto   i'd still go with the specified torque as poi...   Sep 17 2010, 01:02 PM
Cap'n Krusty   I agree with Dave (realred). It would be well for...   Sep 17 2010, 02:17 PM
mgphoto   I agree with Dave (realred). It would be well fo...   Sep 17 2010, 04:59 PM
Cap'n Krusty   I agree with Dave (realred). It would be well f...   Sep 18 2010, 07:58 AM
mgphoto   [quote name='mgphoto' post='1372291' date='Sep 17...   Sep 18 2010, 09:41 AM
mgphoto   [quote name='mgphoto' post='1372291' date='Sep 1...   Sep 18 2010, 12:30 PM
mgphoto   [quote name='mgphoto' post='1372503' date='Sep 18...   Sep 18 2010, 04:40 PM
brer   [quote name='mgphoto' post='1372503' date='Sep 1...   Sep 18 2010, 06:58 PM
Cap'n Krusty   [quote name='mgphoto' post='1372291' date='Sep 1...   Sep 18 2010, 07:40 PM
charliew   Nickel antisieze is for high temperature. Solid br...   Sep 17 2010, 05:08 PM
Krieger   Didn't someone reccomend heating the copper ga...   Sep 17 2010, 07:58 PM
dangrouche   yes by all means, flame the new copper gaskets til...   Sep 17 2010, 08:42 PM
solex   I had it with the copper plated nuts, and pulling ...   Sep 18 2010, 11:14 AM
mgphoto   I got it to work by using a 10mm x 1.25 helicoil a...   Sep 20 2010, 10:39 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:59 PM
