Valve Spring Compressor Recommendations Please |
tornik550 |
Sep 18 2010, 08:38 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
Maybe I am doing something wrong but removing valve springs on my 914 has been a real pain. I have tried two different types. I can get the springs off but it is a real pain. I have a C type compressor from sears- didn't work. I also have the type that grips the spring and when you screw the knob in the spring compresses- never works as planned.
Any recommendations for a easy to use valve spring compressor? There has so be one that is much easier. |
messix |
Sep 18 2010, 08:45 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
what are you having trouble with? getting the retainer off?
when you compress the spring smack the the valve with a soft hammer to pop the retainer up then you can take the keepers out. |
tornik550 |
Sep 18 2010, 09:00 PM
what are you having trouble with? getting the retainer off? when you compress the spring smack the the valve with a soft hammer to pop the retainer up then you can take the keepers out. When I use the compressor that grabs the sides of the springs and screws in, if I grip the valve compressor at the bottom of the spring, I cannot get a good grip and the compressor often pops off. I cannot get a good grip because of the mound of metal that sticks up and hold the valve guide. If I try to grip the spring further up beyond where the metal mount ends, I can compress the spring but not enough to get the keepers off. |
Lo-Fi Version | Time is now: 1st June 2024 - 01:33 PM |
