> Vintage racer build
jhelgesen
post May 20 2010, 06:35 AM
We started cage work for a vintage racer 914-6...
Customer brought in a decent stripped tub, fitted for a complete fiberglass fender setup.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i184.photobucket.com-9299-1274358902.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i184.photobucket.com-9299-1274358902.2.jpg)
We started in with the main hoop
(IMG:http://www.914world.com/bbs2/uploads_offsite/i184.photobucket.com-9299-1274358902.3.jpg)
We'll be tying in all the suspension points.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i184.photobucket.com-9299-1274358902.4.jpg)
Trial fit the door bars last night.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i184.photobucket.com-9299-1274358903.5.jpg)
sean_v8_914
post Sep 21 2010, 08:01 AM
Chingon 601
OT: I was watching monster truck jam. Blue Thunder hit some jumps and both rear shock consoles came apart. then they showed the carnage...WTF? it all came apart at the welds. can someone with real welding experience explain that? I say cold joints and poor penetration.
rick 918-S
post Sep 21 2010, 08:21 AM
Hey nice rack! -Celette
QUOTE(sean_v8_914 @ Sep 21 2010, 09:01 AM) *
If it was 4130 it is likely poor penetration. (monster trucks likely would use light 4130) The other problem with welding 4130 is the rate of cooling. Mig welding 4130 can result in a concentrated local heating of the tubes with a quick flash cooling. This will cause a brittle condition and lock in stress. IIRC Tig welding can even be worse as the heat concentration is even more concentrated with a faster cooling cycle. In welding body panel seams tig is ideal because of the small heating and your ability to concentrate the work to a smaller area minimizing the warp factor.
That's why experimental air frames are gas welded. The molecules expand slower with the torch and further down the tubes. The tubes hold heat longer after the welding process is completed. Cooling is slower allowing the tubes to naturalize (tube and weld metal) restoring the strength.
Mild steel DOM can be mig welded with great success. It's a little heavier.
jhelgesen   Vintage racer build   May 20 2010, 06:35 AM
JmuRiz   Looks good, but damn, you have my wall stripe idea...   May 20 2010, 09:07 AM
jhelgesen   Looks good, but damn, you have my wall stripe ide...   May 20 2010, 09:10 AM
Racer Chris   I hope you're not welding the roll cage togeth...   May 20 2010, 11:24 AM
jhelgesen   I hope you're not welding the roll cage toget...   May 20 2010, 11:34 AM
jimkelly   if you can - pls be descriptive on the install of ...   May 20 2010, 12:22 PM
quadracerx   I was wondering about those fenders and how they a...   May 20 2010, 02:09 PM
carr914   I hope you're not welding the roll cage toget...   May 21 2010, 04:16 AM
jhelgesen   I hope you're not welding the roll cage toge...   May 21 2010, 04:22 AM
quadracerx   Anyone have any suggestions on how to fasten these...   Sep 20 2010, 09:59 PM
carr914   The fact that it is a race car, I would think that...   Sep 21 2010, 04:37 AM
scotty b   The fact that it is a race car, I would think tha...   Sep 21 2010, 05:22 AM
jhelgesen   Quick release fasteners were not allowed by the sa...   Sep 21 2010, 05:46 AM
carr914   B)-->
- Lo-Fi Version Time is now: 2nd October 2026 - 04:40 PM
