| ein 6er |
Mar 19 2004, 07:13 PM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
because the 2nd time i pulled it, i didn't have to remove the carbs and fan shroud!! what a pleasure that was!!
i didn't think it was possible to pull the alternator out, without pulling everything off!! thanks to krk and his very helpful thread and fotos which helped me tremendously the 1st time i pulled my alt. from what i've learned through this process, is that the alt and fan on the 6cyl engines can seize in the housing and on the shaft over time and can be a bitch to get off. if you've never had yours out you will probably need to pull the carbs and the shroud to make it all easier. and also to have a good look under the shroud and clean everything up. remember to antiseize everything on reassembly when i had to pull my alt for the 2nd time, (within a week) i reeeeeeeally didn't want to pull everything off again. i had to pull the fan out then turn the fan housing sideways and then pull the alt out. barely enough room to get it out. saved a lot of time!! doug |
| ein 6er |
Mar 20 2004, 11:13 PM
thanks kim!!
it looks better in there because i had taken it all out a few days before and cleaned it all up!! (IMG:style_emoticons/default/laugh.gif) i had the fan housing and fan media blasted and then i clear coated them with a high temp clear coat. i also did a little fiberglass work on the shroud and painted it. doug |
ein 6er i've had to pull my alt twice in the -6 Mar 19 2004, 07:13 PM
krk Dude,
You rock -- I would not have thought that p... Mar 19 2004, 08:11 PM
Jeffs9146
ein 6er i couldn't believe it either!!! i ... Mar 19 2004, 10:23 PM
ein 6er reinstalled the alt today and took a few pics. i... Mar 20 2004, 09:26 PM
ein 6er 2nd
the housing strap tied back and my telescopin... Mar 20 2004, 09:30 PM
ein 6er 3
the left airvent and the small sheetmetal piece... Mar 20 2004, 09:32 PM
ein 6er 4
with the strap off, the housing can be tilted f... Mar 20 2004, 09:35 PM
ein 6er 5
removing the wires on the alt. internal regulat... Mar 20 2004, 09:36 PM
ein 6er 6
with the wires off the alt. the housing can be ... Mar 20 2004, 09:39 PM
ein 6er 7
even though i had just had the alt out i still ... Mar 20 2004, 09:41 PM
ein 6er 8
turn the housing sideways as far as you can, it... Mar 20 2004, 09:45 PM
ein 6er 9
it has to rotate as it comes out. this is anoth... Mar 20 2004, 09:47 PM
ein 6er 10
i had to let the strap fall back in place so t... Mar 20 2004, 09:50 PM
krk Doug,
Awesome pics! (btw, your engine compart... Mar 20 2004, 10:34 PM
ClayPerrine I just used this article to pull and reinstall the... Oct 30 2005, 12:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th September 2026 - 05:40 AM |
