> carb air leak?, occasioally surging idle
VaccaRabite
post Sep 22 2010, 08:03 PM
En Garde!
I am having a weird issue with my carbs.
They will go along fine at 1100 RPM idle all day. Suddenly I will stop at a sign or red light and the idle will climb from 1100 to 1700 and my car will start making unsynced carb noises. Sometimes it will settle back town if I tap the gas peddle, sometimes not. Once the idle surges, it will be like that for a while when I stop, and then it will suddenly drop back down to 1100 RPM and and behave nicely.
I am guessing that I have an intermittant air leak in one of my carbs. Anything else I need to be looking at?
My theories, in order of what I think is likely:
1) air leak somewhere
2) gas leaking past the inlet valve
3) weirdness with the linkage
I have not been able to recreate the issue at home, its always when I am on the road so I don't yet know which carb is acting up. Its worse if I am driving the car hard, but will happen when I am just cruising around town some too.
Ideas?
Zach
904svo
post Sep 22 2010, 08:58 PM
904SVO
I don't think you have a air leak, air leak would made the engine slow down. I would suggest you check your linkage it sound like its twisting and hitting something
at times. I had a problem like this one time and found the spark plug wire was getting caught in the linkage and stopping it from hitting the idle stop.
- Lo-Fi Version Time is now: 8th July 2025 - 09:05 PM
