Brake Master Cylinder, 17mm vs 23mm |
LotusJoe |
Sep 20 2010, 04:29 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I'm considering upgrading my master cylinder. I have installed the bigger BMW 320 Front Calipers and have Stock Calipers on the rear. I see from other threads that the 19mm master cylinder is a common upgrade, but what about 23mm. Automotion sells a 23mm as an upgrade, but it seem to me that it may to much for my application.
Todd Enlund |
Sep 23 2010, 12:08 AM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
Slight correction: Pressure in a closed system is the same at all points. 30 PSI at the master cylinder is 30 PSI at the brake caliper. Pressure x surface area will give you the (total) force on the piston. The inverse will give you the travel of the piston.
ChrisFoley |
Sep 23 2010, 11:22 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:20 AM |
