| Barry Brisco |
Sep 26 2010, 02:29 PM
Newbie ![]() Group: Members Posts: 17 Joined: 8-October 09 From: California Member No.: 10,905 Region Association: None |
I've run a search for posts talking about "compression test values" but can't find an answer to my question, and my Owner's Manual and Haynes repair manual don't seem to tell me either: what are normal compression test values in a 914?
These numbers are for a 1.7 engine with an unknown number of miles, it's in a 914 that is for sale: #1 130 #2 150 #3 140 #4 150 I am concerned about the #1 cylinder. That is a 13% drop from the highest cylinders. Here are some online references about how much of a difference is acceptable between cylinders, and what indicates a potential problem: http://www.automedia.com/Engine_Compressio...ccr20050801cc/2 QUOTE If all the cylinders check out within 10 or so PSI of each other, and those numbers sync up with the factory specifications, then you're good to go. If one or more of the cylinders show a difference of 15 or more PSI, then there are problems inside http://www.freeengineinfo.com/compression-test.htm QUOTE The cylinders should all read within 5-10 psi of each other. http://www.aa1car.com/library/compression.htm QUOTE As a rule, most engines should have 140 to 160 lbs. of cranking compression with no more than 10% difference between any of the cylinders. So, at this point I'm thinking that this 1.7 engine is a bit tired and in the near future it will likely need some major attention: maybe a bad exhaust valve, maybe worse. And yes, a leakdown test would be helpful. Comments? Thanks, Barry |
| Jake Raby |
Sep 26 2010, 02:51 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Were these numbers gathered with the throttle held open or closed? engine hot or cold? Did you follow up with a leak down test?
What was the elevation at the test location? Generally a 10% differential lowest to highest is the max acceptable, but I have seen engines tested with the throttle closed that had differentials due to chambed filling differences with the throttle closed. |
Barry Brisco What are normal compression test values? Sep 26 2010, 02:29 PM
Barry Brisco Hi Jake,
Thanks for your reply. According to the... Sep 26 2010, 04:18 PM
Jake Raby You might want to re-do it and do a leak down test... Sep 26 2010, 04:48 PM
tod914 One time back in band camp, I had a shop do a comp... Sep 26 2010, 05:51 PM
Barry Brisco I certainly agree that Jake is an expert on 914 en... Sep 26 2010, 06:24 PM
Jake Raby I have seen numbers that high with the butterfly c... Sep 26 2010, 06:27 PM
naro914 so you're saying that my 225 on 4 of my 6 cyli... Sep 26 2010, 08:16 PM
Krieger Buy the car based on how much rust it has. This i... Sep 26 2010, 09:02 PM
brant
Buy the car based on how much rust it has. This ... Sep 26 2010, 10:00 PM
Barry Brisco What are typical compression test values in a 914 ... Sep 27 2010, 05:00 PM
Jake Raby 150-165 is a good number at sea level for a bone s... Sep 27 2010, 05:08 PM
Barry Brisco
150-165 is a good number at sea level for a bone ... Sep 28 2010, 08:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:47 PM |
