> What are normal compression test values?
Barry Brisco
post Sep 26 2010, 02:29 PM
I've run a search for posts talking about "compression test values" but can't find an answer to my question, and my Owner's Manual and Haynes repair manual don't seem to tell me either: what are normal compression test values in a 914?
These numbers are for a 1.7 engine with an unknown number of miles, it's in a 914 that is for sale:
#1 130
#2 150
#3 140
#4 150
I am concerned about the #1 cylinder. That is a 13% drop from the highest cylinders.
Here are some online references about how much of a difference is acceptable between cylinders, and what indicates a potential problem:
http://www.automedia.com/Engine_Compressio...ccr20050801cc/2
If all the cylinders check out within 10 or so PSI of each other, and those numbers sync up with the factory specifications, then you're good to go.
If one or more of the cylinders show a difference of 15 or more PSI, then there are problems inside
http://www.freeengineinfo.com/compression-test.htm
The cylinders should all read within 5-10 psi of each other.
http://www.aa1car.com/library/compression.htm
As a rule, most engines should have 140 to 160 lbs. of cranking compression with no more than 10% difference between any of the cylinders.
So, at this point I'm thinking that this 1.7 engine is a bit tired and in the near future it will likely need some major attention: maybe a bad exhaust valve, maybe worse.
And yes, a leakdown test would be helpful.
Comments?
Thanks,
Barry
naro914
post Sep 26 2010, 08:16 PM
Losing my mind...
so you're saying that my 225 on 4 of my 6 cylinders, WITH slightly blown head gaskets may be a bit high??? (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 11:01 AM
