Hard starting when warm, 10-15 min/ stop 10 min/ hard to start |
Tom |
Sep 10 2009, 01:45 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
76 2.0 d-jet. stock displacement, hydraulics, with smog removed and backdated exhaust to 74 2.0 SSI's with Triad.
Runs great. Pulls hard to redline in 4th with no missing. Idles 850-950 when warm. Starts up when cold just great and idles 700-800. After running 10-15 minutes to town and going in the store for 10-15 minutes, come back out and turns over but doesn't want to fire. Pedal to the floor and turn over for 30-40 seconds and it gets faster and faster and finally fires up. Then runs great. If it sets for an hour or more , no problem in firing right up. Searched here and the only thing I can see that may be causing this is the distributor plate spring(s)? The wiring is all fairly new, so I don't think that would be the problem. Checked all of the connections and they are clean and tight. If the dist plate is sticking in the full advance would that give me these symptoms and how would I fix that? Grease? Special type? Thanks for any help, Tom |
Tom |
Sep 27 2010, 08:09 AM
Well, it is a year later and I only had this happen once this summer, but I haven't been driving the car much as my back has been giving me grief. I used the "pedal down before starting" the one time it didn't want to fire and it started much faster. I usually just have to turn the key to start with no throttle applied to get this car to start up and then it idles OK. When this doesn't get the car to start, I turn the key to off, press pedal to the floor, then try starting again. Started up in less than 10 seconds.
Tom |
Lo-Fi Version | Time is now: 9th June 2024 - 08:39 PM |
