| VaccaRabite |
Sep 19 2010, 09:08 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,878 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Well. Huh. Look at that. I guess we DID have a good time at ECC. More info will be forthcoming. Zach (probably an idiot, but only 1/2 an idiot.) |
| ChrisFoley |
Sep 28 2010, 07:14 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,030 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Carbon Fiber will make it lighter/faster! (IMG:style_emoticons/default/smile.gif)
This deck lid weighs in at 8.8lbs. ![]() And the humps will give people something to talk about. (IMG:style_emoticons/default/biggrin.gif) ![]() |
| PeeGreen 914 |
Sep 28 2010, 10:16 AM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
Carbon Fiber will make it lighter/faster! (IMG:style_emoticons/default/smile.gif) This deck lid weighs in at 8.8lbs. ![]() And the humps will give people something to talk about. (IMG:style_emoticons/default/biggrin.gif) ![]() What are those humps for Chris? Have any more of those laying around? |
| ChrisFoley |
Sep 28 2010, 01:31 PM
| PeeGreen 914 |
Sep 28 2010, 02:16 PM
What are those humps for Chris? Complete foolishness if you ask me. A proper suspension mod job doesn't require exterior body modifications. QUOTE Have any more of those laying around? Sorry, just the one. Yeah, I wasn't even thinking about that as I know you raise the spindals and therefore wouldn't need to do that. |
| ChrisFoley |
Sep 28 2010, 03:22 PM
Yeah, I wasn't even thinking about that as I know you raise the spindals and therefore wouldn't need to do that. Raising the spindles helps the geometry on a lowered car but doesn't have any bearing on the position of the top mounts. The only value to raising the top perches is to prevent the shocks from bottoming out on a drastically lowered car. It would be better to install shorter inserts and shorten the strut housings, but I haven't found a need for that yet either. I can envision some strut inserts, like the Ground Control double adjustables which have adjuster knobs coming out the top, needing extra space for the adjusters above the limitations of the stock bodywork in some installations. |
| PeeGreen 914 |
Sep 28 2010, 03:32 PM
Yeah, I wasn't even thinking about that as I know you raise the spindals and therefore wouldn't need to do that. Raising the spindles helps the geometry on a lowered car but doesn't have any bearing on the position of the top mounts. The only value to raising the top perches is to prevent the shocks from bottoming out on a drastically lowered car. It would be better to install shorter inserts and shorten the strut housings, but I haven't found a need for that yet either. I can envision some strut inserts, like the Ground Control double adjustables which have adjuster knobs coming out the top, needing extra space for the adjusters above the limitations of the stock bodywork in some installations. I have seen some very low 914s and some with JRZs that were lower than I would go yet none had this done. Perhaps they did what you mentioned or they didn't need to do anything (IMG:style_emoticons/default/confused24.gif) Either way, I'm glad people like you hang out here to pass this kind of info on to us (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) |
| ChrisFoley |
Sep 28 2010, 07:34 PM
I have seen some very low 914s and some with JRZs that were lower than I would go yet none had this done. Perhaps they did what you mentioned or they didn't need to do anything (IMG:style_emoticons/default/confused24.gif) Either way, I'm glad people like you hang out here to pass this kind of info on to us (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) Years ago, I had to cut part of the threaded ends off my Bilsteins to clear the stock decklid when I installed some (original) Camberball strut bearings. |
Vacca Rabite And then this happened.... Sep 19 2010, 09:08 PM
avidfanjpl Zach!
Did you buy this to build a racecar?
W... Sep 19 2010, 09:20 PM
GTPatrick Use the Force Luke to Power it . :shades2:
G... Sep 19 2010, 10:40 PM
bandjoey Hay Zach. Someone stole your wheels and bumpers... Sep 19 2010, 10:47 PM
scotty b Yup, team monkey fuckups is on the grid. We talked... Sep 20 2010, 05:58 AM
Vacca Rabite Scott, I have a 2.0 case and rods too. We need to... Sep 20 2010, 06:50 AM
rick 918-S Wow! Very cool! Looks like a great start... Sep 20 2010, 06:56 AM
porsche4me Put stock, rusty everything in it --- and race www... Sep 20 2010, 07:01 AM
porsche4me pix Sep 20 2010, 07:04 AM
hot_shoe914
pix
Is this the car that Leamon sold? Sep 20 2010, 07:08 AM
hot_shoe914 The motor for my silver car that you have Scott is... Sep 20 2010, 07:10 AM
sean_v8_914 no it is not Sep 20 2010, 07:12 AM
sean_v8_914 I was watching that ebay car...I liked it and look... Sep 20 2010, 07:41 AM
pete-stevers this is great!! i like the way you guys ar... Sep 20 2010, 08:57 AM
jsayre914 you guys are CRAZY cool!
Zach, dont you have ... Sep 20 2010, 09:57 AM
jcambo7 This is going to be good...:popcorn: Sep 20 2010, 10:19 AM
mepstein All us married guys can guess the way the conversa... Sep 20 2010, 10:24 AM
Vacca Rabite Erin actually liked the idea, so long as we keep i... Sep 20 2010, 10:27 AM
Erin actually liked the idea, so long as we keep ... Sep 20 2010, 10:49 AM
type47 Start getting your tow vehicle and trailer in line... Sep 20 2010, 10:39 AM
Vacca Rabite
Start getting your tow vehicle and trailer in lin... Sep 20 2010, 11:04 AM
ArtechnikA
We can flat tow the 914 behind it for the time be... Sep 29 2010, 04:03 PM
Dr Evil I see how it is, I wasn't even invited :sad2: Sep 20 2010, 11:12 AM
zymurgist That's because you have motorcycles to ride. Sep 20 2010, 11:27 AM
RobW Congrats... going racing! :trophy:
Look out... Sep 20 2010, 03:40 PM
Phoenix 914-6GT I had looked at that car a few times in pictures. ... Sep 20 2010, 04:51 PM
Root_Werks Well now......this should be interesting. :idea: Sep 20 2010, 05:23 PM
scotty b No need to buy a trailer Zach, I already have one.... Sep 20 2010, 05:31 PM
DanT B)-->
okieflyr This is going to be fun! If your going to ru... Sep 20 2010, 07:54 PM
Dr Evil I am in and EvilWerks will sponsor this retarded e... Sep 20 2010, 08:03 PM
Phoenix 914-6GT :confused: Did you buy this? It's still listed... Sep 27 2010, 11:42 AM
Vacca Rabite Yep, we bought it.
I am trying not to let my enth... Sep 27 2010, 12:32 PM
Dr Evil Money pit! :trophy: Money pit! :trophy: Mo... Sep 27 2010, 12:49 PM
Phoenix 914-6GT
Money pit! :trophy: Money pit! :trophy: M... Sep 27 2010, 01:15 PM
crash914 hmmmm I have all the parts off a 74 sitting here... Sep 27 2010, 04:04 PM
saigon71 :headbanger:
Congrats to all the proud owners... Sep 27 2010, 04:20 PM
scotty b Hi my name is Scott and I'm an addict. It has ... Sep 27 2010, 06:07 PM
AndrewPokrandt B)-->
RJMII
Did you spray paint "Free Candy" on th... Sep 27 2010, 06:20 PM
Vacca Rabite Rock. You were able to get the title stuff worked... Sep 27 2010, 06:25 PM
scotty b It isn't parked down by the river yet. Is it?
... Sep 27 2010, 06:50 PM
Dr Evil With that resume, all you need is a trench coat an... Sep 27 2010, 09:03 PM
Brett W Looks like the car Porsche Doc was selling. It is... Sep 28 2010, 07:26 AM
Britain Smith I know what those humps are for and I have conside... Sep 28 2010, 10:58 AM
Phoenix 914-6GT
I know what those humps are for and I have consid... Sep 28 2010, 12:11 PM
scotty b
I know what those humps are for and I have consi... Sep 28 2010, 12:16 PM
scotty b Why, they're lovely lady humps !!
Loo... Sep 28 2010, 11:09 AM
DanT If you raise the suspension points enough you need... Sep 28 2010, 12:20 PM
Dr Evil Scott, I can help pick the car up this weekend or ... Sep 28 2010, 12:58 PM
MikeSpraggi Zach, Scotty, Mike, would love to have you guys co... Sep 28 2010, 03:35 PM
Brett W http://www.914world.com/bbs2/uploads_offsite/www.h... Sep 29 2010, 07:56 AM
anderssj Got Fuchs? I think I have a set I can loan you gu... Sep 29 2010, 12:41 PM
scotty b Got cookies :) Might have a set of Minis too :D ... Sep 29 2010, 12:46 PM
jamesjedi Is the tub as nice as it looked on Ebay? If so tha... Oct 25 2010, 05:16 PM
scotty b I haven't been able to pick it up yet. I plan ... Oct 25 2010, 06:00 PM
Eric_Shea Is this thing done yet? :confused: Oct 25 2010, 06:42 PM
scotty b
<_... Oct 25 2010, 06:48 PM
scotty b So I made the inaugural run with the new tow vehic... Nov 20 2010, 11:10 AM
scotty b few mo Nov 20 2010, 11:14 AM
scotty b 2 mo Nov 20 2010, 11:14 AM
okieflyr Looks like it is going to be alot of fun. Can... Nov 20 2010, 12:11 PM
scotty b
Looks like it is going to be alot of fun. Can... Nov 20 2010, 12:16 PM
Dr Evil Totally worth it! Nov 20 2010, 03:21 PM
RJMII Nice score! Looks like you guys are going to h... Nov 20 2010, 03:23 PM
Vacca Rabite Lets start thinking about dates for a Richmond wor... Nov 20 2010, 06:39 PM
MDG This'll be cool!
You guys have all the fu... Nov 20 2010, 06:43 PM
J P Stein Looks like the basics are there. Enjoy. Nov 21 2010, 08:35 AM
Mr.242 My favorite is it has STICKERS.....that always mak... Nov 21 2010, 09:37 AM
type47 Need update :idea: PCA Potomac autocross school ... Apr 2 2011, 06:17 AM
scotty b
Need update :idea: PCA Potomac autocross school... Apr 2 2011, 07:26 AM
type47 progress at a snails pace (if that fast). I did a ... Apr 2 2011, 08:36 AM
Dr Evil Not the fastest car on jack stands, but just wait ... Apr 2 2011, 10:26 AM
Vacca Rabite A 4 day weekend around a holiday is probably the o... Apr 2 2011, 12:19 PM
hot_shoe914 You ladies need to hurry up and finish the car so ... Apr 2 2011, 06:57 PM
flipb Tow it to Hershey.
Get commitments ahead of time ... Apr 2 2011, 07:09 PM
Vacca Rabite Last weekend Mike and I were going to go south for... Jul 18 2011, 06:33 PM
saigon71 Good to see you guys back at it & I look forwa... Jul 18 2011, 07:03 PM
scotty b That car is Fuched....but we got one hell of a rol... Jul 18 2011, 07:27 PM
hot_shoe914
That car is Fuched....but we got one hell of a ro... Jul 18 2011, 07:51 PM
balljoint Who is that girl working on the car? She needs a ... Jul 18 2011, 08:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:56 AM |
