| Porschef |
Sep 30 2010, 04:00 PM
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States
They're supposed to burn a little better. Also considering jumping up one heat range.
Any suggestions welcome, thanks. Joe |
| Cap'n Krusty |
Sep 30 2010, 06:29 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Try W8CC, or NGK B5ES. That's as hot as you wanna go. In fact, there may not be any readily available hotter plugs. Shifting at too low RPMs will affect plug fouling, too. If you have carbs, 8s are the way to go with modern fuel and the tendency for carbs to run a LOT richer than EFI.
The Cap'n |
porscheless Thinking of Platinum+2 spark plugs Sep 30 2010, 04:00 PM
Root_Werks Never had much luck with platinum plugs in air coo... Sep 30 2010, 04:31 PM
underthetire Platinum plugs really only work well in high disch... Sep 30 2010, 04:46 PM
a914dude They suck in air cooled motors. Splitfires are wo... Sep 30 2010, 04:49 PM
Cap'n Krusty
They're supposed to burn a little better. Al... Sep 30 2010, 05:08 PM
porscheless Thanks for the replies.
The reason I ask is that ... Sep 30 2010, 05:20 PM
porscheless Cap' n,
Your reply came in before I could fi... Sep 30 2010, 05:41 PM
Vacca Rabite I am wondering about spark plugs too. My plugs se... Sep 30 2010, 06:15 PM
Jeffs9146
This indicates you should step up to a hotter pl... Sep 30 2010, 06:18 PM
Cap'n Krusty
This indicates you should step up to a hotter p... Sep 30 2010, 06:36 PM
Vacca Rabite Thanks Cap'n. I am going to get some of the W... Sep 30 2010, 06:34 PM
Jeffs9146
Yep, running older Webers (ie: running a bit ric... Sep 30 2010, 10:48 PM
70_914
They're supposed to burn a little better. Al... Sep 30 2010, 10:53 PM
Jeffs9146 :agree:
When I tried to run the platinum plugs th... Oct 1 2010, 12:23 AM
Vacca Rabite I am dealing with that now with the stock heat ran... Oct 1 2010, 06:09 AM
Jake Raby I learned about platinum plugs in the early 90s...... Oct 1 2010, 08:12 AM
Root_Werks Frug and egg, you guy's don't listen. :ro... Oct 1 2010, 08:39 AM
Vacca Rabite Is there an appreciable difference between the Bos... Oct 2 2010, 05:43 AM
Cap'n Krusty
Is there an appreciable difference between the Bo... Oct 2 2010, 02:28 PM
Drums66 ...Answer to your ?....no no no :wacko:
:waveby... Oct 2 2010, 11:37 AM
underthetire Zack, try ND Denso plugs if you can't get NGK... Oct 2 2010, 02:32 PM
Kansas 914
Zack, try ND Denso plugs if you can't get NGK... Oct 6 2010, 05:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:51 PM |
