| Gint |
Mar 21 2004, 08:15 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
It's been a looong time since I had a good old fashioned 'murican carb'd V8. My 72 Chvy truck has had an ongoing hot start issue. After running it to full temp and shutting it off and coming back to start after 10 minutes or longer (until it cools off anyway, then everything is fine), you have to open the throttle at least half way to get it to start. And then it runs like crap for a few minutes. Then all is well again. I've suspected fuel boiling for a while now, so I rebuilt the Edelbrock 600 carb today to verify float settings and general health of the carb.
Today after I finished it and drove it and warmed it up, I waited 10 minutes and then tried to restart. The problem still exists. I pulled the air cleaner off and I could hear fuel bubbling. There was fuel leaking from the secondary throttle shaft on the right side of the carb as well. Taking the carb top off revealed fuel in the right side bowl still bubbling a tiny bit. The float bowl is dumping fuel into the secondary cavity and causing the leak at the secondary throttle shaft and dumping fuel into the manifold. So root cause is determined. I have a buddy that is going to give me a phenolic spacer and gasket that I will install later this week. Is this fairly typical? |
rick 918-S Sounds like a fair assessment. Fuel will expand wh... Mar 21 2004, 08:24 PM
Gint Thanks Rich. But everything is good as I just reb... Mar 21 2004, 08:27 PM
PatW Holley's like to blow the f'in power valve... Mar 21 2004, 09:30 PM
Gint I forgot to mention it's an Edelbrock Performe... Mar 21 2004, 10:50 PM
PatW
Gint Now I'm more confused. Mine doesn't look ... Mar 21 2004, 11:41 PM
PatW
Gint No sweat. Thanks for the replies. You made me th... Mar 21 2004, 11:53 PM
Gint Anybody? All you V8 guys awake? Mar 22 2004, 04:33 PM
John2kx Gint,
I run the same carb you have in my 914. Wa... Mar 22 2004, 04:58 PM
John2kx Gint,
Sorry for the confusion but I'm running... Mar 22 2004, 05:02 PM
rick 918-S Don't know the Carter that well. I know the Q-... Mar 22 2004, 07:10 PM
DuckRyder Q-Jets are bad about leaking from the well plugs o... Mar 22 2004, 07:26 PM
Rgreen914 Ran a couple of small blocks with Q-jets and never... Mar 23 2004, 03:24 AM
Rgreen914 Just remembered, back in the 70's, some drag r... Mar 23 2004, 03:34 AM
Gint 1/2" phenolic spacer went on this evening. Prelim... Mar 23 2004, 08:46 PM
andys Gint,
I'm assuming intake and exhaust manifol... Mar 23 2004, 09:53 PM
Gint Thanks Andy. Intake is an Edlebrock Performer alu... Mar 23 2004, 09:56 PM
andys
Gint You're talkin about an exhaust heat riser. Go... Mar 23 2004, 10:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:19 AM |
