| Porschef |
Sep 30 2010, 04:00 PM
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States
They're supposed to burn a little better. Also considering jumping up one heat range.
Any suggestions welcome, thanks. Joe |
| Drums66 |
Oct 2 2010, 11:37 AM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
...Answer to your ?....no no no (IMG:style_emoticons/default/wacko.gif)
(IMG:style_emoticons/default/bye1.gif) (ngk come to mind) |
porscheless Thinking of Platinum+2 spark plugs Sep 30 2010, 04:00 PM
Root_Werks Never had much luck with platinum plugs in air coo... Sep 30 2010, 04:31 PM
underthetire Platinum plugs really only work well in high disch... Sep 30 2010, 04:46 PM
a914dude They suck in air cooled motors. Splitfires are wo... Sep 30 2010, 04:49 PM
Cap'n Krusty
They're supposed to burn a little better. Al... Sep 30 2010, 05:08 PM
porscheless Thanks for the replies.
The reason I ask is that ... Sep 30 2010, 05:20 PM
porscheless Cap' n,
Your reply came in before I could fi... Sep 30 2010, 05:41 PM
Vacca Rabite I am wondering about spark plugs too. My plugs se... Sep 30 2010, 06:15 PM
Jeffs9146
This indicates you should step up to a hotter pl... Sep 30 2010, 06:18 PM
Cap'n Krusty
This indicates you should step up to a hotter p... Sep 30 2010, 06:36 PM
Cap'n Krusty Try W8CC, or NGK B5ES. That's as hot as you w... Sep 30 2010, 06:29 PM
Vacca Rabite Thanks Cap'n. I am going to get some of the W... Sep 30 2010, 06:34 PM
Jeffs9146
Yep, running older Webers (ie: running a bit ric... Sep 30 2010, 10:48 PM
70_914
They're supposed to burn a little better. Al... Sep 30 2010, 10:53 PM
Jeffs9146 :agree:
When I tried to run the platinum plugs th... Oct 1 2010, 12:23 AM
Vacca Rabite I am dealing with that now with the stock heat ran... Oct 1 2010, 06:09 AM
Jake Raby I learned about platinum plugs in the early 90s...... Oct 1 2010, 08:12 AM
Root_Werks Frug and egg, you guy's don't listen. :ro... Oct 1 2010, 08:39 AM
Vacca Rabite Is there an appreciable difference between the Bos... Oct 2 2010, 05:43 AM
Cap'n Krusty
Is there an appreciable difference between the Bo... Oct 2 2010, 02:28 PM
underthetire Zack, try ND Denso plugs if you can't get NGK... Oct 2 2010, 02:32 PM
Kansas 914
Zack, try ND Denso plugs if you can't get NGK... Oct 6 2010, 05:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:55 PM |
