> Sorta OT - V8 carb Q, On topic for the V8 teener guys
Gint
post Mar 21 2004, 08:15 PM
Mike Ginter
It's been a looong time since I had a good old fashioned 'murican carb'd V8. My 72 Chvy truck has had an ongoing hot start issue. After running it to full temp and shutting it off and coming back to start after 10 minutes or longer (until it cools off anyway, then everything is fine), you have to open the throttle at least half way to get it to start. And then it runs like crap for a few minutes. Then all is well again. I've suspected fuel boiling for a while now, so I rebuilt the Edelbrock 600 carb today to verify float settings and general health of the carb.
Today after I finished it and drove it and warmed it up, I waited 10 minutes and then tried to restart. The problem still exists. I pulled the air cleaner off and I could hear fuel bubbling. There was fuel leaking from the secondary throttle shaft on the right side of the carb as well. Taking the carb top off revealed fuel in the right side bowl still bubbling a tiny bit. The float bowl is dumping fuel into the secondary cavity and causing the leak at the secondary throttle shaft and dumping fuel into the manifold. So root cause is determined. I have a buddy that is going to give me a phenolic spacer and gasket that I will install later this week.
Is this fairly typical?
PatW
post Mar 21 2004, 11:36 PM
Wassup?
QUOTE(Gint @ Mar 21 2004, 08:50 PM)
I forgot to mention it's an Edelbrock Performer 600 (square bore). Not too old either. It's on a Performer aluminum intake as well. Q-Jet copy yes?
All Q-Jets are spreadbores. What you have likley is a Carter AFB copy. I've known folks that have gone through a whole shelf of Holley's before they got one that would work right. Maybe you just have a bad one?.
A Q-Jet.. AKA Rochester Quadra-Jet
Gint   Sorta OT - V8 carb Q   Mar 21 2004, 08:15 PM
rick 918-S   Sounds like a fair assessment. Fuel will expand wh...   Mar 21 2004, 08:24 PM
Gint   Thanks Rich. But everything is good as I just reb...   Mar 21 2004, 08:27 PM
PatW   Holley's like to blow the f'in power valve...   Mar 21 2004, 09:30 PM
Gint   I forgot to mention it's an Edelbrock Performe...   Mar 21 2004, 10:50 PM
PatW     Mar 21 2004, 11:36 PM
Gint   Now I'm more confused. Mine doesn't look ...   Mar 21 2004, 11:41 PM
PatW     Mar 21 2004, 11:49 PM
Gint   No sweat. Thanks for the replies. You made me th...   Mar 21 2004, 11:53 PM
Gint   Anybody? All you V8 guys awake?   Mar 22 2004, 04:33 PM
John2kx   Gint, I run the same carb you have in my 914. Wa...   Mar 22 2004, 04:58 PM
John2kx   Gint, Sorry for the confusion but I'm running...   Mar 22 2004, 05:02 PM
rick 918-S   Don't know the Carter that well. I know the Q-...   Mar 22 2004, 07:10 PM
DuckRyder   Q-Jets are bad about leaking from the well plugs o...   Mar 22 2004, 07:26 PM
Rgreen914   Ran a couple of small blocks with Q-jets and never...   Mar 23 2004, 03:24 AM
Rgreen914   Just remembered, back in the 70's, some drag r...   Mar 23 2004, 03:34 AM
Gint   1/2" phenolic spacer went on this evening. Prelim...   Mar 23 2004, 08:46 PM
andys   Gint, I'm assuming intake and exhaust manifol...   Mar 23 2004, 09:53 PM
Gint   Thanks Andy. Intake is an Edlebrock Performer alu...   Mar 23 2004, 09:56 PM
andys     Mar 23 2004, 10:14 PM
Gint   You're talkin about an exhaust heat riser. Go...   Mar 23 2004, 10:18 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:42 PM
