Fresh Air Blower, Sound, but no fury |
rwilner |
Oct 4 2010, 08:35 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
When I put both black levers to the right, I can hear the fresh air fan blowing but the airflow out the defrost and dash vents is quite minimal. The fan does work on all 3 speeds.
Similarly -- I just reattached all my heat, and even with the booster fan going in the engine compartment, there is just not much airflow. The engine compartment hose and the flapper --> firewall hose are new, the HX's are SSIs in good shape as is the rest of the engine compartment plumbing. What level of airflow should I expect? What should i check or refurbish to get better CFMs? |
jim_hoyland |
Oct 4 2010, 02:12 PM
Get that VIN ? Group: Members Posts: 9,313 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Be sure nothing has fallen into the windshield airvents; mine had accumulated a dozen parking ticket stubs. May not be easy to see, but a wire with a hook on the end will find most of them. If there's just one or two, you can hear them vibrate when the fan is set to high and your driving at 50 - 60... (IMG:style_emoticons/default/smile.gif)
rwilner |
Oct 4 2010, 05:53 PM
ok, an update:
Did some investigating and the passenger side blower is kicking butt, it's just the drivers side that is weak. I took the hose off the drivers side at the blower, and it seemed strong. When I put the heat on, the red dashboard lever did not seem to effect the heat airflow direction on the driver's side -- it seemed more or less evenly split between the foot and dash. So the symptoms: - weak flow on driver's side from fresh air blower -- pass side is strong - flow is fairly weak on driver's side from heat - red lever doesn't effect airflow Any ideas? is it likely mechanical adjustment of the control cables? Is my driver's side front trunk flapper NFG? |
Lo-Fi Version | Time is now: 1st June 2024 - 08:49 AM |
