Fresh Air Blower, Sound, but no fury |
rwilner |
Oct 4 2010, 08:35 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
When I put both black levers to the right, I can hear the fresh air fan blowing but the airflow out the defrost and dash vents is quite minimal. The fan does work on all 3 speeds.
Similarly -- I just reattached all my heat, and even with the booster fan going in the engine compartment, there is just not much airflow. The engine compartment hose and the flapper --> firewall hose are new, the HX's are SSIs in good shape as is the rest of the engine compartment plumbing. What level of airflow should I expect? What should i check or refurbish to get better CFMs? |
ChrisFoley |
Oct 5 2010, 09:52 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Rich, the McMaster link you provided is for a 5/16" od tube. That won't work too well.
AFAIK McMaster has only one product that's suitable to replace those 60mm id paper tubes. I bought some "Blo-R-Vac" rubber hose from them in the past that works good. Its almost $4/ft. though. |
rwilner |
Oct 5 2010, 10:54 AM
Rich, the McMaster link you provided is for a 5/16" od tube. That won't work too well. AFAIK McMaster has only one product that's suitable to replace those 60mm id paper tubes. I bought some "Blo-R-Vac" rubber hose from them in the past that works good. Its almost $4/ft. though. yep -- turns out .232" is not equal to 2.32"!! that's what I get for looking up parts quickly in-between meetings... $4/ft is way better than $17.50/ft for this stuff. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:09 AM |
