V8 Radiator Sources |
kyracedog |
Mar 31 2010, 08:44 PM
Newbie Group: Members Posts: 19 Joined: 19-November 05 From: kentucky Member No.: 5,151 |
Ok V8 guys, what type of radiators did you use? I know Renegade sells a kit that works, but $1100 is a budget buster. Already have the dual fans to use, so don't need them.
Looking for ideas/suggestions/sources. Thanks. |
BIGKAT_83 |
Apr 1 2010, 06:52 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
A couple of good radiators to use for the 914 are from Afco and C&R racing.
The afco 80133n is stocked by Summit racing and cost about $250 This is the C&R modified and can be ordered direct from them. A little higher at $325 or so the last time I checked. It comes with a screw in intake hose for the high pressure side. They will also custom build this for any size you need for a little more. Also a good source for the Fans and shroud is a set up from the last Chrysler front wheel drive New Yorkers. These have a dual fan set up on a nice shroud that is a easy mod to fit any radiator. One of the fan motors have a low and high speed winding. Easy to find at the pick and pulls for $20 |
BRAVE_HELIOS |
Oct 9 2010, 08:47 AM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
..... Also a good source for the Fans and shroud is a set up from the last Chrysler front wheel drive New Yorkers. These have a dual fan set up on a nice shroud that is a easy mod to fit any radiator. One of the fan motors have a low and high speed winding. Easy to find at the pick and pulls for $20
[/quote] At this point I think I'm going to purchase the AFCO 80133N radiator. I believe there is an advantage to the double pass radiator not having a filler neck and having the drain petcock at the very top. Will the Chrysler fan setup fit on the AFCO radiator? Do you know how many CFM the fan setup flows? Thanks. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 11:50 AM |
