Creamsicle Project, Still tinkering... now it's running! |
poorsche914 |
Sep 6 2010, 05:57 PM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
I finally decided to tackle getting my LE started and thought the long Labor Day weekend would be the perfect time. I had already replaced the fuel tank and lines up front and had sourced '74 FI parts and bought a new Optima battery. The final piece to the puzzle was a working fuel pump which I got a couple weeks ago.
So this weekend I installed the pump and put power to it. It ran but wasn't pumping fuel up to the engine. I heard gurgling from the tank. Low fuel level. So I added more gas and tried again. Success! Fuel was now being pumped to the fuel rail but there were several leaks. Took care of these and cranked it. Nothing. Pulled two injectors and saw they were not firing. Swapped out harnesses and more of the same. (IMG:style_emoticons/default/sad.gif) I have both a single progressive and dual 40s. I seriously contemplated pulling the FI and installing the single Weber after a rebuild just to get the car running. After chatting with mipstein I had a few things I thought I should try first. I put power to each injector and they all fired so that took bad injectors out of the equation. I looked over pbanders d-jet page for clues. Somewhere along the way I realized the ECU was not getting power and perhaps the relay board was suspect. Having two extra boards, I picked one, transferred relays, etc and plugged it into the 914's harnesses. Turned the key, let fuel pressure build, cranked it and she fired right up!!! (IMG:style_emoticons/default/mueba.gif) Vacuum lines, etc aren't hooked up so it revved high before I turned it off. Next step is to hook up all the vac lines (and install new shift bushings, install accel pedal, etc, etc) Goal is to have it on the road for MUSR11 (IMG:style_emoticons/default/driving.gif) |
robby750 |
Oct 12 2010, 03:11 PM
Senior Member Group: Members Posts: 646 Joined: 6-April 03 From: Lexington, Ky Member No.: 521 Region Association: South East States |
You are so close to Vonore that it would be worth it to rent a trailer and truck to get it there and get it fixed. Besides, we all love Creamsicles.
poorsche914 |
Oct 12 2010, 03:15 PM
You are so close to Vonore that it would be worth it to rent a trailer and truck to get it there and get it fixed. Besides, we all love Creamsicles. |
poorsche914 |
Oct 13 2010, 10:57 AM
Well... I swapped out fuel pumps again (IMG:style_emoticons/default/dry.gif)
The one removed was totally dead. Put power to it and nothing. The other one ran fine but I thought maybe wasn't pumping correctly. After swapping relays around, I thought I would give this pump another try. What do you know... it works. https://www.youtube.com/watch?v=HoiEbYTlLJo A bit on the smoky side (IMG:style_emoticons/default/blink.gif) https://www.youtube.com/watch?v=Qm4RtLmT2Oo |
hot_shoe914 |
Oct 13 2010, 05:19 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Well... I swapped out fuel pumps again (IMG:style_emoticons/default/dry.gif) The one removed was totally dead. Put power to it and nothing. The other one ran fine but I thought maybe wasn't pumping correctly. After swapping relays around, I thought I would give this pump another try. What do you know... it works. https://www.youtube.com/watch?v=HoiEbYTlLJo A bit on the smoky side (IMG:style_emoticons/default/blink.gif) https://www.youtube.com/watch?v=Qm4RtLmT2Oo Does this mean you are driving it to the ramble? |
Lo-Fi Version | Time is now: 12th June 2024 - 08:06 AM |
