Mallory ignition questions, Partial success! |
VaccaRabite |
Oct 10 2010, 05:59 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
My carbed 2056 uses a Mallory Unilite ignition. All summer long I have been fighting intermitant misses leading to the motor dieing at idle. After dicking with the carbs and adding fresh spark plugs, I am now moving to ignition.
So here is how my system is set up. Bosch blue coil. Mallory Unilite ignition. The ignition is behind a resistor block. MSD spiral wound plug wires. NKG b5es plugs pregapped (one heat range hotter then stock as suggested in the resent spark plug thread) . My tach is not dancing when I have a miss. The idle indicated drops as expected, no drama. So I don't think that the coil is grounding out or arcing. As I understand the Mallory dizzy, it either works or it does not work, and there is not a lot of in-between. My primary suspects are the plug wires. I am using the MSD spiral wound wires suggested for use with the Mallory, and I have only been using them this season. Since you are not supposed to use the regular plug wires with a Mallory (as they can somehow cause the optical unit to burn out) buying replacement wires on a hunch is kinda expensive. Am I chasing my tail with this? Also, I am using the stock gap. I think I am supposed to be able to use a wider gap with the Mallory, which will give better ignition. What kind of gap should I be shooting for? If it does turn out to be the plug wires as the problem area, should I go back to the stock heat range plugs, or stay with the hotter ranged plugs? Oh, and for the "go back to FI" crowd, my motor is using a cam that would cause D Jet to commit suicide. In this case, it is not an option. Zach |
VaccaRabite |
Oct 13 2010, 05:29 PM
Okay, I just tested my timing at idle (1000 rpm) and 4K.
At idle, it is set at 8 degrees BTDC. At 4K it is set to 28 degrees BTDC. This would indicate that I am 4 degrees retarded at idle, and may be my issue. Also, at idle the timing mark seemed to dance around just a little bit. Less then a degree to be sure, never out of sight. At higher RPM, it was very steady. Zach |
Lo-Fi Version | Time is now: 31st May 2024 - 06:20 PM |
