| 914itis |
Oct 18 2010, 10:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
looking for instructions on push rod replacement with pictures.
| VaccaRabite |
Oct 19 2010, 09:30 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,921 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Not hard to do, and you can do it with the engine in your car. Pelican may have a photo essay on it, or maybe aircooled.net.
Get the back end of your car in the air. you are going to be spending some time under there so get it to a height where you have enough room to work and are comfortable. Use jackstands. 1) Pop the valve covers off. Just look at everything for a moment so you have an idea of how its going to come out. The valves are on a rocking arm that is held on to the head via an axle. That axle is supported by 2 bolts. There are 2 axles. There is also a spring wire keeper that spans the head and has prods that go into the push rod tubes. 2) undo the 4 bolts that hold the adjusters to the head, and remove both the entire adjuster assembly. These are oily, and can slide apart. Its not a big deal if they do - but try and keep them together. Put them in the valve cover top so you don't lose anything. Be careful of the little wire spring thing that runs across the head. You don't want to mangle it. 3) pull the pushrods out. mark them somehow so you know what tube they go back into. It is important not to get your pushrods mixed up. Except some people say it isn't important. You can make your own choice on this one, but I suggest marking them so that they go back into the same bore they came out of. 4) the lifters may or may not slide on out. If they do, make sure they go back into the bore they came out of. 5) with a pair of plyers, grab the pushrod tube under the cylinders and carefully rotate it back and forth until you can get it loose and it slides out. With the engine in the car, you probably won't be able to get the tube all the way out unless you lower fan side of the engine a little. Unless you find a ton of RTV or silicone sealant in there, I don't think you need to bother fully removing the tubes. Again, a lifter may come out. It is important that the lifter finds its way back into the same bore it came out of. 6) remove the old rubber seals, clean up the sealing surface and replace with the VITON o-rings. Lube them with motor oil. Again, different folks do this differently. Some like to place them in dry, others like to use grease, others like to use engine oil. My bias here is clear. Get ready, the only tricky part is coming up. 7) Replace the pushrod tubes back into engine case and head. What is so tricky about that?! Well, you also have to make sure that the pushrod tubes get fully seated without pinching and cutting the O-ring. This is why its good to clean the sealing surfaces and then lube with some oil. It is a tight fit getting them back in, and if they pinch they are almost certainly ruined. Once the tubes are in, inspect (you may need a mirror) to make sure they are fully seated and in good shape (no pinching, no cuts). 8) Put the heads back together. Use a new cork gasket on the rocker covers. if done correctly, your pushrod tubes will not leak. DO NOT use sealant of ANY kind on them. You may stop a leak now with it now, but when the sealant fails (and it will) you will never got them sealed again unless you can get rid of all the old sealant. Which is a HUGE PITA. |
ppetion push rhod Oct 18 2010, 10:28 PM
ppetion
looking for instructions on push rod replacement ... Oct 19 2010, 11:10 AM
type47 Go Zach! The only thing I would add is when re... Oct 19 2010, 11:17 AM
Cevan I used thread sealant (Permatex high temp) on the ... Oct 19 2010, 11:26 AM
stugray If it is just one pushrod, you can replace it with... Oct 19 2010, 11:34 AM
Racer Chris
If it is just one pushrod, you can replace it wit... Oct 19 2010, 12:12 PM
stugray LOL!
"That would work if he had a Type 1 ... Oct 19 2010, 10:18 PM
realred914 :sawzall: ditto on use of viton material o-rings i... Oct 20 2010, 09:52 AM
ppetion
:sawzall: ditto on use of viton material o-rings ... Oct 23 2010, 05:48 PM
Cap'n Krusty You may have a problem here.
Before we get to t... Oct 23 2010, 06:34 PM
ppetion
Before we get to ... Oct 23 2010, 09:19 PM
ppetion
Before we get to... Oct 23 2010, 09:22 PM
Cevan
As for the poster who used sealant, that's a ... Oct 25 2010, 04:44 PM
Vacca Rabite If you ran the engine for 30 minutes and had no le... Oct 23 2010, 10:11 PM
ppetion
If you ran the engine for 30 minutes and had no l... Oct 23 2010, 10:34 PM
Vacca Rabite I use Brad Penn 20w50.
I can't find it locally... Oct 23 2010, 10:37 PM
ppetion
I can't find it locall... Oct 23 2010, 10:48 PM
Vacca Rabite This is another one of those cans of worms that fo... Oct 24 2010, 07:50 AM
ppetion
This is another one of those cans of worms that f... Oct 24 2010, 07:33 PM
ppetion
This is another one of those cans of worms that ... Oct 24 2010, 07:43 PM
Vacca Rabite 4 quarts for a stock motor. Just make sure that w... Oct 25 2010, 06:52 AM
ppetion
4 quarts for a stock motor. Just make sure that ... Oct 25 2010, 08:53 AM
Vacca Rabite Yeah, I got it last night.
If you are driving arou... Oct 25 2010, 09:18 AM
ppetion
If you are driving aro... Oct 25 2010, 09:30 AM
Vacca Rabite your dizzy may not be a vac advance dizzy. Yes, I... Oct 25 2010, 09:41 AM
ppetion
your dizzy may not be a vac advance dizzy. Yes, ... Oct 25 2010, 04:35 PM
ppetion I did not understand your last post Cap'n Oct 25 2010, 05:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th October 2026 - 05:41 AM |
