| stugray |
Oct 18 2010, 02:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have rebuilt a type IV a couple of times, but I was young & naive.
This will be a 2.0L with stock FI for vintage racing. 1 - How do I hook up the stock fuel pump line(s) to a fuel cell? 2 - are there any Cams other than the stock one that will give me increased performance while still using the stock FI? 3 - What compression ratio should I target? I am working that step right now - CC'ing the heads & setting the deck height. 4 - The CAM thrust bearing has just one side with the thrust plate on it. If I recall, when I upgraded my last 914, the guy at the performance shop gave me TWO with the thrust bearing on it (one for each side). Should I be looking for those? 5 - After splitting the case, there were 2 or 3 "bumps" that needed a little "flattening out" with a file. Can the case be damaged by trying to clean up the nasty spots, or is there a way for me to make sure to get it right? I imagine that the only thing I could do would be to remove all the studs and rub each side over some sandpaper taped down to a very flat surface... Any help is appreciated. Stu |
| stugray |
Oct 19 2010, 11:06 AM
Cupomeat,
1 - Still trying to find a legal fuel cell. It needs a bladder and (I guess) three ports. 2 - I looked at the Raby website and it looks like I can only get a cam if I buy the whole $500 package. I am tempted, but if I blow that kind of dough (in addition to all the other stuff I need) right now, I wont be on the track for another year. If I just knew the lift & duration of an "improved cam", I could have one made myself locally. 3 - Based on my measurements, I am at about 8.2 right now. This motor has concave pistons. To up the CR, I would need to reduce the head volume or get domed pistons, right? How much does it cost to have the heads flycut for a lower volume combustion chamber? They read 60ccs now. 4 - I see that the aircooled technology website has the dual thrust bearings. 5 - The worst bump was on both sides and at the very top. I didnt goe nuts with the file. I just kept it perfectly flat on the case halves and took off any high spots. Bleyseng, Wouldnt I want a HIGHER CR being at high altitude as the air is thinner? New questions: 6 - I dont have a flywheel for this engine, but I have two in my 1.7s. Are they identical between the 1.7 & the 2.0? 7 - the dipstick tube is broken (as usual ;-(. Can I extract it & replace it myself? I have a slide hammer. I was thinking putting a piece of all-thread thru it & putting a nut on the end & tapping it out. If that works, where do I get a new tube? Stu |
stugray Engine rebuild, a few questions Oct 18 2010, 02:40 PM
Cupomeat Ok, I'll give it a go and I am sure you will h... Oct 18 2010, 03:01 PM
Bleyseng 2. The absolute best cams for Djet FI are Raby cam... Oct 19 2010, 04:02 AM
Cupomeat
Cupomeat,
1 - Still trying to find a legal fuel ... Oct 19 2010, 11:15 AM
ArtechnikA
1 - Still trying to find a legal fuel cell. It ne... Oct 19 2010, 11:52 AM
Jake Raby
Understand this:
My package INCLUDES ALL the ite... Oct 19 2010, 01:01 PM
stugray ArtechnikA,
Thanks for all the comments
"T... Oct 19 2010, 01:30 PM
ArtechnikA
...there are HUNDREDS of choices out there and ve... Oct 19 2010, 06:13 PM
stugray Jake Raby,
Thanks for the detailed reply.
I have ... Oct 19 2010, 01:33 PM
Jake Raby My team is here to help you, don't worry about... Oct 19 2010, 06:42 PM
stugray Thanks again for the comments.
Here are some pics... Oct 20 2010, 07:02 AM
Jake Raby Get rid of those sodium filled exhaust valves... Oct 20 2010, 07:45 AM
stugray Ok, Jake.
I have new valves and purchased your ra... Jan 21 2012, 12:53 PM
stugray Ok, so what I am learning here is that nobody has ... Jan 23 2012, 08:13 PM
jaxdream
Ok, so what I am learning here is that nobody has... Jan 24 2012, 09:12 AM
Jake Raby
You'd waste your time.. All stock chambers ar... Jan 23 2012, 10:38 PM
stugray Ok Next update:
I have the European Motor Works, ... Aug 26 2012, 06:26 PM
cgnj Hi,
60 cc's is what I got on my rebuilt stock... Aug 26 2012, 07:44 PM
Valy Bringing the heads to 48cc will probably remove th... Aug 26 2012, 08:23 PM
stugray Thanks for the tips.
I will target 50cc if I can ... Aug 27 2012, 12:00 AM
Valy You need big washers to spread the load.
I got min... Aug 27 2012, 10:50 AM
Racer Chris Stu,
A tight deck is much better for efficient com... Aug 27 2012, 11:25 AM
Dave_Darling Are the 2.0 heads the ones where it is easy to bre... Aug 27 2012, 03:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 09:32 PM |
