Dam 914 still doesn’t start regularly |
Kevan |
Mar 22 2004, 09:15 PM
Newbie Group: Members Posts: 31 Joined: 5-December 03 From: Paso Robles,ca Member No.: 1,421 |
My 914 still doesn’t start regularly. I turn the key and every time I heir the buzz my guess is the D-Jet fuel pumping and then it might start or nothing happens. Once it starts cranking it will start just fine. Here is a list of what I’ve done. What am I missing??? What could be wrong?
New battery Clean the connections on the battery New ends on the positive wires to the battery New ignition switch Clean and replaced connections on the starter solenoid Cleaned ground strap connections from tranny to trunk Kevan |
SirAndy |
Mar 23 2004, 04:15 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Dave Bell @ Mar 23 2004, 02:08 PM) so here is a diagram followed by photos of a relay set up for your starter. thing about the relays is, you just put a band-aid on a problem you can't find. will work (at least for a while) but won't fix what's actually broken. if in good working order, the starter circuit doesn't need a relay ... Andy |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:05 PM |
