> OT (somewhat) 911S 2.2l Motor maladies, Steady Throttle popping issue
Cupomeat
post Oct 22 2010, 02:16 PM
missing my NY 914 in VA
My Dad's 911S has an issue with intake popping while normal driving.
BACKGROUND; Engine fully rebuilt (within 1.5k miles) and valves adjusted about 2 weeks ago. Engine was an MFI engine converted to PMOs before we bought the car. (someday I dream to go back to MFI.)
SYMPTOM: Prior to the valve adjust a sporadic 'Popping" was coming from the intake as a small backfire on a regular basis.
After the valve adjust (first since rebuild), it runs better but still pops. When I go up there, I am going to check the rotor and dist cap, but anything else to check?
Sadly, the motor does not run nearly as strongly after the rebuild as it did before the rebuild (crazy, I know). The top end, just isn't there now like it was before. I don't get the needed time to spend with the car, tinkering, as I'd like to see why.
But, back to the popping, It seems to happen mostly while cruising at part throttle.
My logic says that it is ignition and that a spark plug (or carbon build up?) is firing while the intake valve is open.
Does this makes sense? David asked me if they carbs had been rebuilt, and it has been years since they have, but there are no flat spots or stumbles while driving.
Thanks
Eric_Shea
post Oct 22 2010, 03:20 PM
PMB Performance
This from a guy whose ass-dragger sounded like a 50 caliber machine gun on deaccel in Torrey .......
I speak from "experience". I also think I was so rich there you were crying.
- Lo-Fi Version Time is now: 6th July 2025 - 01:29 PM
