| Steve |
Oct 4 2010, 06:31 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,111 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
This can't be good. The seam is separating under the battery and under the right side of the engine lid support. I also noticed a crack above the GT chassis stiffener on the same side. I searched everywhere else in the area and it looks fine. I wonder if its rusting out from the inside? Any ideas on what this means? Do I need to pull the motor to fix it? Replace the whole section or just weld it up?
(IMG:style_emoticons/default/welder.gif) Here are the pictures. ![]() ![]() ![]() |
| Steve |
Oct 22 2010, 05:48 PM
Steve This can't be good! Oct 4 2010, 06:31 PM
kg6dxn I got one that looks worse. The hell hole is bad, ... Oct 4 2010, 06:41 PM
Steve
I got one that looks worse. The hell hole is bad,... Oct 4 2010, 06:55 PM
Root_Werks :(
I bet there is some soft metal up in there.
... Oct 5 2010, 09:27 AM
burton73 I noticed when I put my GT stiffing kit on the rig... Oct 5 2010, 10:16 AM
RobW Is it the 3.2? Oct 5 2010, 10:22 AM
John Can you beg or borrow a boroscope?
I would drill ... Oct 5 2010, 09:17 PM
Steve Thanks for the reply's and the help!! ... Oct 5 2010, 10:28 PM
sean_v8_914 this is common on GT stiffened cars. the chassis m... Oct 6 2010, 09:11 AM
ConeDodger
this is common on GT stiffened cars. the chassis ... Oct 6 2010, 09:33 AM
sean_v8_914 do you "track" this 914/6? Oct 6 2010, 09:13 AM
Steve It was tracked at Willow Springs for two years by ... Oct 6 2010, 05:42 PM
John I still recommend taking a look inside the box. L... Oct 6 2010, 07:32 PM
sean_v8_914 I'll bet a cheese burger that this car is not ... Oct 6 2010, 08:46 PM
Steve Can someone take a look at my car at G&R's... Oct 22 2010, 05:46 PM
sean_v8_914 I'll be up in mountain view at the Buffalo Spr... Oct 23 2010, 11:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 04:51 PM |
