> fuel injection issue, trigger points?
luskesq
post Oct 24 2010, 06:40 PM
Have a '70 1.7 that I picked up that hasn't been run in years. Gone through ignition, points, plugs, timing and it runs . . . badly. Discovered when running that I can pull the ignition wires to 1 & 2 and it runs the same. No injector clicking with key on and opening the throttle switch on 1 or 2. 3 & 4 click. Could the problem be the trigger points and do all stock 1070 1.7's have trigger points?
brp986s
post Oct 24 2010, 07:39 PM
All stock 1.7 have the trigger points in the distributor. The way to test them is have someone turn over the engine while you measure continuity between the center and either of the the outer pins of the distributor. The circuit should open and close once per rev of the distributor rotor. One side of the trigger will fire injectors 1 & 4, the other 2 & 3. As the triggers wear, the slider blocks wear out - the circuit fails to open, and the ecu doesn't receive the signal to fire the injectors.The function of the trigger points is unrelated to the tps. good luck.
- Lo-Fi Version Time is now: 3rd July 2025 - 02:47 AM
